Hey folks!
I'm Brandon, long time lurker. Bought this r33 Gtst series 1 1994 back in 06 with 70k on the clock used to be Burgandy was resprayed black before I got it(including all that rice! :P). Few basic mods cat back 3inch and an apexi pod filter. Kept it pretty stock and lived most of its life in the garage/daily run abouts. Resprayed in phoenix yellow with gold pearl in 2010, changed rims around the same time. Got the itch in 2016 to fix it up after the radiator had a small leak and I managed to rip the front bar off, after it got caught over the lip of a gutter while parked.  Cleaned up the interior and replaced the drivers side seat, passenger one is still sitting in the garage for when I have some spare time. Stock stereo replaced with a double din kenwood, rear stock speakers replaced(could see sunlight shining through from the parcel shelf in to the boot ;/ ) boot tidied up and reupholstered. still need to cover the dash surround as its coating has peeled off over time in the Aussie summers and replace the steering wheel.
 Now running a sidemount nismo cooler, bc racing coil overs, hicas lockbar fitted and boosted to 10psi @197kw on stock internals and ecu 208k on the clock still going strong. Tuned by the boys at GarageWorx in Vic Hoppers Crossing. In getting the clutch replaced today. Few too many kms and hard starts I guess and it had started to burn its face off smelt horrible.
Wondering if anyone has any suggestions for a replacement steering wheel? Since I don't need an airbag as stock wheel doesn't have one I can kind of use whatever, I believe I'm still required to have the middle covered (no exposed metal)? Would also like something not as large as the stock wheel, as it touches my thighs on entry/exit.
Edited by B.C
  • Like 1
https://www.sau.com.au/forums/topic/477042-vic-r33-gtst-purchased-back-in-06/
I've been informed my memory has gone to shit my cousin reminded me on the weekend that I actually purchased it back in 2003 when he was still living back my aunts place, he said it was the last time I let him drive it too reminding me I'm also a tightass...lol
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
