@Wheezy depending on who manufactured your turbo, there may well have been impeller options. With Kinugawa there certainly was. From recall, I selected the "middle spec" turbine which was 11 blade (stock being 12, and 9 being the highest flowing + lightest), and "standard" 6+6 compressor.  There was also a full 12 blade billet comp impeller option for high boost applications.  Thrust bearing was about 270 degrees for all units.
With all of that, I ran the 11 blade turbine, 12cm housing, standard 12 blade comp, and the compact comp cover.  Main target was decent turbine flow efficiency, and a modest power requirement under 400rwhp.  It performed the required task, reliably.  And there was room for much more.  Boost response was satisfactory, not "awesome".  At the price point there was little to complain about.
I reckon yours will be a good thing, interested to see whether it can run to your power target.
What I really like is your choice of Emtron and some decent sensors.  Suggest you ditch that OEM CAS.  I found greatly reduced timing scatter with a NZ Wiring sensor kit, if that's any help.
Mines a genuine Trust turbo. So whatever they did back in the day.
RE: CAS, will probably go the High Octane kit.
Probably not happening before tune, perhaps that way I can keep the power down for now and get used to driving it I guess :)
  • Like 1
Came so close to starting today.
Has fuel, but no spark.
Spun the CAS by hand, but no spark.
Coila have 12v on the multimeter.
Ran an ignition test on the ECU and the coils fire.
Noticed the battery voltage goes to 11.7v when I crank.
So, charging the battery up to be safe, but it's brand new.
Looking at ECU settings to see if there's something going on to disable the spark.
Edited by Wheezy
  • Like 2
Spent the day flushing out the old fuel and putting some new E85 in it along with some fuel doctor.
Based on my digging through the logs and talking to my tuner, it looks like the emtron is designed to suit the Neo CAS.
Will double check with Emtron, but probably I just need to do a pin swap for the signal wire and trigger wire and she should be good to go.
Engine bay back together more or less.
Apparently the Pyrex Gas Lens for my Tig is turning up this week so I can finish making my new intake pipe.
Then it just needs the panels put back on, clutch and brakes bled and a new fuel pump for insurance and it's ready for the dyno.
  • Like 2
You know it's tune week when...
Viscous clutch decided it didn't want to live anymore.
Ordered a new one from Nissan.
Cost of that hurt the bot bot a little.
Then went to bleed the brakes and found $80 of rbf650 on my floor. Fuuuuuuuuuu.
Got the brake line junction out.
Messed that up badly... My own fault.
To distract myself I did a final tidy up on the GTR loom I replaced my 20 loom with.
Less crusty now.
Will go get some essentials for my pets tomorrow and grab a new fitting from Hopper stoppers
  • Like 2
Brake line junction being picked up tomorrow..
And viscous clutch is due too.
Went to change the fuel pump and decided to clean up the wiring at the bulkhead as I've not touched it since owning the car.
Looks like it's had a bit of a hard life...
It will only be temporary until I get dual pumps next year with an aftermarket hanger etc.
Had a good laugh at the f**ked up wiring job too...
Explains why we had mystery wires when doing the silvertop 20 conversion 14 years ago.
#f**ktuneweek
Tig skills getting better.
Might clean up the welds tomorrow with some polish.
Went back to a standard cup instead of the fancy gas lens, not skilled enough for them yet.
Edited by Wheezy
  • Like 3
17 minutes ago, PranK said:
That looks amazing!
Thanks man, much appreciated. It's 90% the way there to what I imagined it would be.
I've never gone all out like this before on a car.
So much planning involved however. Other than the long motor build, I can't imagine how much it would cost to pay someone to have do it all for me.
A few things I need to tidy up and others is do different. Hopefully there isn't a next time for this cars engine bay.
For something completely different, I have a VN Berlina to build (thinking LS6) and a Honda SL70 mini bike to restore.
  • Like 1
Nothing like keeping yourself busy! :)
Mini bike restore sounds like a lot of fun!
Lots of work, was my family's farm bike for years.
Saw a mint one in Tokyo last year and got inspired. Hope to restore it with my kid as a project for him so he can learn to ride
  • Like 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
