2 hours ago, Wheezy said:
Lots of work, was my family's farm bike for years.
Saw a mint one in Tokyo last year and got inspired. Hope to restore it with my kid as a project for him so he can learn to ride
Yes! I want to do this!!
Making a custom layout for my digital dash.
Thoughts?
Seems to fit the theme of MAGA but more arrogance.
Might see if I can make the background change on redline for a combination of the two.
Edited by Wheezy
  • Haha 5
On 8/20/2020 at 4:30 PM, Wheezy said:
Powertune digital dash.
Basically a raspberry pi
AH. I remember when that was launched. I threw the image of mine up and the kid knew exactly who I was when I did it.
I'm doing another currently from scratch this time. 5" wide screen.
Not much to update.
Dash insert turned up today and I test fitted the screen. Had to slightly enlarge the mount holes due to differences in the Powertune vs. the insert. (As they are both 3D printed).
Waiting on the pilot lights (Turning up Tomorrow/Friday).
Waiting for stage 4 restrictions to ease up before I get a wheel alignment and put some km's on it.
  • Like 2
  • 4 weeks later...
Haven't done much lately with the car.
Test fitted the dash on the weekend.
Just need to order some more wiring and DTM plugs.
Then drill the holes for the led pilot lights.
(Indicators, handbrake, high beam and alarm).
Might do fuel level through the Emtron as it has an input.
2 hours ago, robbo_rb180 said:
That's nice, how's the quality of the dash facia?
Pretty happy with it considering the price and lack of support for R31 things in general.
You can tell it's 3D printed, from the back. But otherwise it has a nice paint/finish added to the front size.
  • Like 2
On 10/10/2020 at 1:15 PM, Roy said:
I hear crickets....why don't I hear hits of big rpm and Trust goodness!!!!
BAHAHAHAHAHAHA.
Changed position at work and am working EU hours. Daytime is daddy daycare and sleep :P
Hopefully next month more time for fun as I will split my shift between EU and AU time.
Still need to finish wiring the dash and putting some Bosch (oil/fuel) sensors to the Emtron before I drive it again.
Ordered the bits this week, so hopefully get stuck into the wiring with my brother in law once restrictions are lifted.
  • 1 month later...
Very little updates here.
With the new job hours and some other life plans I've had even less time for this.
Still have the dash apart and cannot drive it. Chequered Tuning is booked out for the rest of 2020, so I'm in no rush to get km's on it to get back on the dyno.
So I used this as an excuse for more goodies for the interior & change the standard Trust dump pipe to a Vband as it's a pain to remove and put back on.
Hopefully take it on some drives over the xmas break :)
  • Like 1
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
