For Sale - Audi A4 Racecar (Turbo Quattro)
Audi A4 Racecar for sale. $7000
Located in Melbourne.
Audi A4 Quattro Turbo racecar for sale.
1.8L 4 Cyl. Turbo, Intercooled.
Full weld in cage.
Cutout switch (internal & external).
Tow points (front and back).
Fix back race seat (standard seat rail)
Fabricated floor (drivers side)
Window net
Weight reduced via seats, caprets, some electronics, some trims.
Car will come with a huge number of spares including;
Radiator
Coil packs
Some sensors
Assorted hoses
Assorted belts
Trims
New brake discs and pads
Fluids to suit car
8 x Audi OEM 17" Wheels old tires (still ok for track days).
5 x Aftermerket 16" wheels and tires
5 x Audi A4 16" wheels and tires
17s are good for tracks, 16s are good for dirt etc.
OEM manual (for what its worth)
Haynes manual (for fixing anything)
Car starts, runs, moves under its own power.
Will probably need new pads and discs before next event.
Car can also come with Floor jack, ramps and jack stands.
What's missing from it you ask? Seat belts. The belts that were in it were sold out of it as they were for a Hans device helmet.
The belts were going to run out of date so I sold them otherwise, this car is a start it, drive it, ready to go racecar.
Car will meet tech checks for all up to the Pro/Am categories of racing. It's been well overdone for entry level motorsport.
Can be flexible on price (especially for SAU members) if some items are removed from the sale, but would much prefer to get the entire lot out of my garage.20190519_155926.jpg20190519_155933.jpg20190519_160116.jpg20190519_160058.jpg20190519_160159.jpg20190519_160228.jpg20190519_160255.jpg20190519_160325.jpg20190519_160415.jpg20190519_161033.jpg
  • Like 1
  • 4 weeks later...
This car is $5k for the entire lot, it takes a up a lot of space in my driveway/carport. I'd be happy to entertain all interest (interstate etc). I can prove it runs, moves etc. Happy to take more photos (of specific items) or create videos. Happy to assist with transportation depending on the situation (i'm not going to drive it to Broome).
The car is genuine, and is (I feel) quite cheap. The cost of the safety items alone tallys to around $4k, so call it another 1k for the car, the wheels and the spares.
There's a Lemons event coming up at Calder park. They're using the banked turns, surely someone is keen to participate with this car.
  • 2 months later...
Bump. I still have this car. Am still looking to move it on. Let me know if you are interested, it's a good car and a genuine sale.
Price is 5k for the lot. Come and see the car, we're nearly back into good weather for car shenanigans... :)
  • 1 year later...
Bump on the oldest for sale thread going.
I still have this car, i'm done looking at it and want it out of my garage space. It's only advertised here and as such, i'm willing to listen to ANY offer you put up. I may not accept your offer of one cheeseburger and a diet coke, but I sure as heck won't be offended.
There's nothing wrong with the car and would suit someone whose keen to jump into budget motorsport. Comes with more spares than you can poke a stick at.
I assume the lights/sirens are for those last, desperate passing manoeuvres LOL.
If you don't mind I'll pass this on to others I know that might be interested but don't come here.    If there's any interest I'll let you know with contact numbers.      Suitable trailer is probably going to be the sticking point.
  • Like 1
  • 4 weeks later...
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
