On 20/05/2019 at 9:45 AM, GTSBoy said:
Not if you want it registered perhaps. The engineering would not be fun. Plus the Barra is physically not a good fit in R32s.  Very large in the wrong dimensional directions. Consider an NA v8
There is something else i think would be totally awesome.
There's a company called Zero-EV that have an r32 gtst with a full electric conversion. They modified a tesla model-X engine (custom control module) and gearbox (quafe LSD). I think it makes about 660 hp (or kw?) At the wheels
And that would be totally awesome. They have videos on youtube of the build, the engineering, and then one of it doing a burnout
  • Like 1
On 20/05/2019 at 9:33 AM, niZmO_Man said:
Welcome. Sounds like a cool project, post it your conversion here, would be good to document it.
You could also start a Barra vs. RB vs. 2JZ "discussion" :P
It'll be a while before the barra swap happens. But you're right that would be cool.
For now I'd settle for knowing how to use SAU properly. Once i figure that out then I'll think about managing a thread haha
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
