Getting around to doing the much needed maintenance on my skyline.
It's a 1991 R32 GT-R. I realized that it still has the stock shocks and pretty sure they're blown. Pretty bouncy in the rear and the roads here in TX suck.
Is there a strut that can be interchanged with the stock ones. All I see when I look up the part  number on the strut is OEM from Japan for way more than I'd like to pay. For the price of 2 I minus well get some coilovers.
Pic for reference with the part number:
https://www.sau.com.au/forums/topic/477080-r32-gtr-rear-strut-replacement/
Just now, GTSBoy said:
No non nonononononono.
Why use stock type stuff? If you wish to retain stock type, at least upgrade to Bilstein B6. Otherwise, there are a large number of excellent coilover options in the US, and here.
Or that, Haha. Coilovers are probably best, but depends on your budget
1 hour ago, GTSBoy said:
Budget is not a consideration. Anyone who owns an R32 GTR has already committed to spending the purchase price again every 2 years.
Not meeeeeee :D
OP, you should have local Koni and Bilstein options. Hell, if you have standard springs, throw some KYB dampers in and enjoy.
If you're after adjustability, spend the money on KW (unless you just want height adjustment, then you can get TEIN street, they're relatively comfortable and cheaper).
Nismo S-Tune is a good bolt in upgrade, KYB dampers and uprated springs. Dunno if it's worth the money though.
E.g.:
https://www.tein.com/srch/us_search.php?maker=NISSAN&carmodel=SKYLINE&modelyear=1989-1994&item=default
Yeah I didnt see the point in buying stock when they're almost the price of some good coils. I was just looking to see if there was some cross over stock rear struts I can use and get locally. I appreciate the feed back and the links. Actually seen some twins for about 900 the demon tweeks website has them for cheaper but I wonder if that's not including shipping.
Teins have traditionally had very hard springs and dampers that may or may not have been appropriately matched. They have reputedly gotten a lot better in the last 10 years, but I'm still leery of them. Hell, even just 7(?) years ago I decided to go with modified Bilsteins and separate springs rather than coilovers. But these days, I would just spend the money. ~$2.5k buys you a hell of a lot of very well built coilover these days.
5 hours ago, Jjtxaz24 said:
So are the teins listed above a cheap alternative? Poor ride quality? Cant be worse than these blown shocks I have now.
My friends 33 gtr came off the boat with a set of tein coilovers and if you told me it had some 4x4 fence post cut to size and stuck in there to hold the car up I would have believed it. The ride was so stiff you would lift out of the seat if you hit a dip in the road, after an afternoon out you were sore. I took them off the car and installed a different set a year or two ago but I can'r remember the brand off the top of my head.  Ive heard good thing about the fortune 500 coilovers with swift springs, built in the states so easy to get but I haven't had any first had experience.
Comparing used Bilstein in my Subaru wagon, the TEIN Street Basis Z is quite comfortable. Body control is overall on par (some positives, some negatives). For example, the short travel you can definitely feel, but the "softer" dampening controls bumps quite well even on 6kg/5kg springs. Considering the price, if you're after some standard replacements + lowering they are great.
Note that Street is different to the other TEINs, which would be rough as (e.g. the old ones that I had on my 32R).
It really depends on your intended use and how much you want to spend.
I'm not going to be tracking or racing the car. My use at the moment until I get the maintenance done and all the little things out the way will be just daily driving it and hitting up car shows. Cars not in rough shape but it does have its imperfections. Once that's done I can focus in the stuff I really wanna do and get a little more horsepower out of it.
The roads here in TX arent the best. Pretty rough in most parts. Suspension at the moment is super soft, well the rears are. I'm not sure how the GTR suspension is stock but it looks to be rear struts are Original and the fronts are some sort of coils. The level the car sits at is great though. Heres some pics. IMG_1374.thumb.jpg.95435d3b4c3609d09c80ae4ace263b61.jpg20190511_201631.thumb.jpg.f903d87517147e9ae636387d4f335c37.jpg
when I had it lifted off the floor see how droopy the rear suspension is?
  • Like 1
If you go Tein you really need the Mono tube stuff. The valving is far superior compared to any of the Tein twin tube stuff. I had Tein NR twin tube about 7 - 10 years ago and they were so shit, super hard, very bad dampening twin tube shock, way worse than stock GTR shocks. Got rid of them and went Tein Mono flex about 5 years ago and was completely amazed at the difference. Excellent twisty stuff control, compliant on rough roads, way more so than any stock Gtr, evo, sti or wrx suspension I've been in. Definitely better on bad roads than my 2001 or 2015 wrx's or my stock 33 v spec suspension. No problem with high speeds either, like 250kph+ on undulating highway roads (we had open speed limits then), and Mono flex is supposed to be track coilovers.
Stretch for some good mono tube based ones if you can afford it, the valving difference is worth it. If you just want to replace the blown shocks with something decent from Tein I'm sure the streets will be adequate enough, as it will still be better than brand new Nissan suspension, let alone stuffed ones.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
