Anyone use this with E85?
Lucas upper cylinder lubricant, NOT Lucas Safeguard
"Apparently" it aids in lubricating injectors and fuel pumps, I've seen simular stuff advertised specifically for E85,  VP racing M2, which (again) "apparently" is the same stuff as this or the safeguard (safeguard isn't compatible with diesel though).
Anyone use this with 98?
Anyone use this with diesel?
I used it years ago in a old Torana I had, as no leaded fuel was available, seemed to work just fine, I think it was 2ml per 1ltr of fuel.
It also "apparently" boosts octane, by how much?????? 0.0001 RON, but, it at least doesn't knock it down, "apparently".
Why am I asking, a mate was having issues with his fuel pump, "apparently" the E85 he was using ate it, from there we started talking about fuel injectors and the requirement or advantage to lubricant the plunger, yada yada yada, just add beer.....
This post has been brought to you today by curiosity and the word "apparently".
It was used ages ago by many [me included for a while] to compensate for cushioning effect of lead in super.  Was supposed to make your valves and valve seats last longer....because everyone kept telling the world that all our valves and seats would erode away with this unleaded poison we were forced to use.
It may well do this, but with modern valve seats and valves it was proven over time to be totally unnecessary.  And older vehicles with cast valve seats [or cast iron heads with seats cut directly into the head] and 'softer' valves got updated and then went on to do another million miles.
I can remember these sort of additives on every service station counter available in little 40ml plastic shots - one per tank fill.
These days you rarely see it anywhere, and with good reason, it was totally unnecessary.  We lament the loss of super, but the sky didn't fall?
In the case of E85...I don't know, but suspect the same.
There's a very big difference between "lubricant" in upper cylinder lubricant and "lubricant" in terms of what might keep pumps and injectors happy. The former is lead or calcium or some other mineral based thing to cushion the valves on the seats, and the latter is going to need to be some type of oily lube.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
