Dear all,
So... I just faced an issue with my BNR32. I was leaving the carpark (cold start), but i stalled (don't ask why), so the car rolled back down.
THEN, i put it to neutral, and tried starting the car. BUT the car did not start. It was a "crank but no start" situation.
I tried a couple of times, but just will not start. I googled, and came across an article about fuel pump, fuel injectors issue, etc.
THEN, i just tried my luck by cranking the car at 2nd Gear. Miraculously, the engine ignited.
NOW, my question is WHY it happened? and WHAT to fix?
https://www.sau.com.au/forums/topic/477086-professional-helpadvice-needed/
Stock ECU and stock injectors?
If so I'll start with cleaning your AFM, and injectors. If they're clogged or gummed up, it will be a bit too lean to start. If you're in this situation, unplug your coolant temp sensor (2x pin one not the 1x pin one) and it should start.
If not stock ECU, tuned and worked etc. then could be a poor cranking table or coolant/IAT/fuel correction table issue or clogged injectors or anything really.
  • Like 1
Hey! thank you!
I was able to start the engine normal prior to stalling. But after the stall, the car cannot be ignited but cranks (both at 1st gear and neutral).
After a while, the car was able to ignite at second gear. Today, the car starts up normally and even though i stalled it on purpose, the car is working normally.
Is it something that happens normally? What exactly is the issue?
9 minutes ago, GTSBoy said:
Gear position / neutral has nothing to do with it. You have just experienced something weird. As my crystal ball is currently out getting resurfaced, I am unable to discern what caused it. Please call another psychic.
HAHA thank you. Didn't really understand what went wrong. Thought might get some answers from here!
Thank you all! Just an update and maybe someone could explain to me why so:
SO, i tried stalling the car the same way i did before. Again, the car could not be ignited. But this time round, i tapped the throttle whilst cranking the car and it worked.
My guess is that there isn't enough fuel injected when the car was climbing the slope of the carpark - causing it difficulty to start the engine (?).
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
