I recently bought an R33 gtst with series 2 RB25DET. I turned the boost down on my manual boost controller when I gave it an oil change now whenever It hits boost or even half throttle it will misfire and WON'T STOP at all... Check engine came on after oil change
Has link g4 440 injectors bigger turbo 42mm wastgate and straight pipe... Tuned to 240kw on 15 psi
Changing coil packs and sparks this week.. any help appreciated thanks
https://www.sau.com.au/forums/topic/477087-rb25det-misfire-under-loadboost/
Splitfires are not expensive now. They are the same price as they have ever been, possibly cheaper in real terms. They are still the cheapest & easiest way to do a coil upgrade.
They are, however, not really any different in terms of performance & quality than the original Nissan ones, which have been popping up here and there over the last few years. The problem with buying "OEM" ones is that they are probably easier to counterfeit.
The smart approach these days is to replace with a modern pencil coil. Your choices are to buy a kit that uses Toyota/Denso coils (such as Yaris, or any of the 1ZZ tyes) and necessary wiring adaptation & mounting bracket, or to buy Nissan type (R35 GTR, VQ370 types) and the necessary stalk adapters and mounting plate. The Toyota options are cheaper as kits. The easiest/best Nissan options will cost you over $1k, but are the absolutely f**king duck's nuts in terms of performance capability, for a coil that can fit in the factory spot.
Edited by GTSBoy
  • Thanks 1
2 hours ago, BASHERnissan said:
Split fires are so expensive wow
Not really, $600-odd for bolt in is good. When you compare it to cheapo red/yellow ones, yes, but they're on par with OEM and cheaper than the R35 route.
In the mean time, gap your spark plugs to 0.7mm and see if that makes a difference.
Dead coil packs affect the whole range....not just higher up.  Red is dead, Blue is true.
If you don't believe us, take the coils and get them tested.
Otherwise take it to a workshop and get their input.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
