hi to one and all,iv been wanting a skyline since my 20's not 20 anymore more 40's haha.i  just got my 33 back in December 2018 i luv it and  been working on it getting it to this point now with body kit and all,that pic was taken at the sakura picnic on Sunday.
the car is a 1995 R33 factory manual turbo.i think im the 3rd owner but would like to find out more about this 33 the rims were on it when i got it, i dont like them haha,i would like to get super advans tri's for it one day
hicas delete from japan,factory fitted with no rear window wiper and a few other bits that iv not seen before. ..id love to find out more like what place it is from in japan who owned it and so on .
plus looking for a good group to join with my car and you guys iv been told are the ones for skylines hence why im here.
  • Like 3
Haha ? it's similar to the greddy one on the blue 33 trust and greddy did... Pretty sure it's called the greddy gracer wing... Not many run them at all I was lucky enough to get my hands on it from a drifter up Bendigo way.... Pic is of the famous r33 by trust and greddy..
Dare to be different and that I am ?
http://zeroauto.co.jp/羽島市mさまよりr33-gt-r-greddy-rx-s-rocを買取させていただきま/
All the specs on that blue demon gtr and some pics ... Out of the top japanese r33's the top secret r33 and the blue 33 trust gtr are my all time favourites
Thanks ? Dare to be different ? ✌️ it's how iv always wanted my 33 to look mean as hell haha ? iv tried to keep true to how the Japanese would do it up.. The stickers on the rear window are the demon is the 33 and the trouble maker is me ?
  • Like 1
That GReddy R33 is now in Australia. Was imported by Advan Performance which is now a BMW shop it seems.
Good looking car, though not sure how I feel about the panda paint. :)
Good looking car, though not sure how I feel about the panda paint. [emoji4]
Ooooooh THAT R33. Now i get it. [emoji848]?
Yep, both ended up in Australia.
Though, the Top Secret one was kinda stripped of its goodness.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
