BASHERnissan Posted May 27, 2019 Share Posted May 27, 2019 Hi I have a R33 gtst s2. My check engine light blinks 4 long blinks followed by 6 fast ones. I looked online for a code that would be 46 but couldn't find anything. The closest is 45 and is injector leak and 47 which is CAS or something... It also misfires SO BAD that you can't even use quarter throttle. These blinks are on start up, while running it stays on. Any ideas what this could be ?? The car also has a link g4, 440cc Injectors and big turbo with 240kw tune. Any help will be much appreciated thanks !! Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/ Share on other sites More sharing options...
Ben C34 Posted May 27, 2019 Share Posted May 27, 2019 Take it to a mechanic. Preferably who did the tune.your chances of an internet diagnosis working out here based on that info is non existant. Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7906405 Share on other sites More sharing options...
GTSBoy Posted May 27, 2019 Share Posted May 27, 2019 1 hour ago, BASHERnissan said: 46 but couldn't find anything. The closest is 45 and is injector leak and 47 which is CAS or something... It also misfires SO BAD that you can't even use quarter throttle. These blinks are on start up, while running it stays on. Any ideas what this could be ?? The car also has a link g4 I've bolded the bits where I think the problem is. Why would an aftermarket ECU have the same fault codes as the Nissan ECU? Surely they have all their own fault codes? Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7906415 Share on other sites More sharing options...
GTSBoy Posted May 27, 2019 Share Posted May 27, 2019 Aaaaaaaaaaaanddd!....... https://www.linkecu.com/software-support/ecu-fault-codes/ Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7906416 Share on other sites More sharing options...
Steve85 Posted May 27, 2019 Share Posted May 27, 2019 These codes are for GTRs. They may be of some use to you. Edit: Uggggh, I've got to start reading these posts properly. If you've got an aftermarket ECU, these won't help. Sorry. [emoji848] Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7906422 Share on other sites More sharing options...
KiwiRS4T Posted May 27, 2019 Share Posted May 27, 2019 1 hour ago, GTSBoy said: I've bolded the bits where I think the problem is. Why would an aftermarket ECU have the same fault codes as the Nissan ECU? Surely they have all their own fault codes? Follow GTSBoy's link to Link and you can ring or email their customer support. Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7906426 Share on other sites More sharing options...
BASHERnissan Posted May 28, 2019 Author Share Posted May 28, 2019 Thanks everyone Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7906528 Share on other sites More sharing options...
DJM Posted February 12, 2020 Share Posted February 12, 2020 Did you have any luck with this issue I just brought a r33 with the same problem Plate LRM20 Same car? Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7924714 Share on other sites More sharing options...
KiwiRS4T Posted February 12, 2020 Share Posted February 12, 2020 9 minutes ago, DJM said: Did you have any luck with this issue I just brought a r33 with the same problem Plate LRM20 Same car? Same ECU? Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7924715 Share on other sites More sharing options...
DJM Posted February 12, 2020 Share Posted February 12, 2020 12 hours ago, KiwiRS4T said: Same ECU? Yes same ecu link g4+ gtrlink I've looked at the code description in that link and not sure what it is Code: 46 Description: An T2 at 5V Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7924740 Share on other sites More sharing options...
GTSBoy Posted February 12, 2020 Share Posted February 12, 2020 An = analogue. T2...dunno, but will no doubt tell you which analogue input it is. at 5V = Saturated analogue input. Sensor is not doing what it is supposed to be doing (ie, giving somewhere between 0.5 and 4.5V or whatever it is set up to do) and is just jamming full sensor voltage. It's f**ked in some way. Link to comment https://www.sau.com.au/forums/topic/477187-help-r33-gtst-check-engine-light-blinking/#findComment-7924743 Share on other sites More sharing options...
