My car was tuned in June and we managed to extract 178 rwkw and 408 Nm. The problem then (and partly that was because the guy was not familiar with e-manage features) was that when boost gets up to the 13.5+ psi (0.93 bar) mark the engine cuts out. Differing theories on what caused this include spark plugs, coil packs, injectors maxing out, boost limiter.
I've just recently played around with the e-manage and found a feature that is able to eliminate boost cut by clamping the air flow meter signal at the rpm point where boost cut occurs.
The boost cut has now gone and I've just run up to 14.7 psi (1.04 bar)!
Good thing these computers. :)
https://www.sau.com.au/forums/topic/47721-beyond-10-bar/
The air flow meter probably maxed out - mine reached around 5volts airflow on around 1bar... so I'd watch what I do with fuelling after the point that happens. Someone I know blew their RB25DET recently by not compensating for what happens after 100% flow of the AFM is reached - so more air, no more fuel, lean out - detonation, death :ghost:
https://www.sau.com.au/forums/topic/47721-beyond-10-bar/#findComment-962782
  krzysiu said:
Fuel Pump?
:confused:...why would he need a fuel pump. LOL, its a late model R34 with std turbo and i doubt it has a lazy / failing fuel pump and at that power i wouldnt expect that he needs extra rail pressure...coudl be wrong but what make s you think he need a new fuel pump?
https://www.sau.com.au/forums/topic/47721-beyond-10-bar/#findComment-962788
  EnricoPalazzo said:
I think the guy solved the problem, hence his post. It was boost cut was still set at 13.5psi, he changed it and his car is now sweet
:confused: I always seem to confuse others whenever I post...
The air flow meter was definitely maxing out hence the power cut: too much air too little fuel. There is the danger of detonation but that is fixed by adding a bit more fuel where its needed through the injector control map of e-manage. The boost limiter cut feature of e-manage "tricks" the ecu into thinking that the AFM has not maxxed-out yet but in reality more air is being pushed through (dangerous). Therefore, this situation needed to be compensated by adding more fuel.
https://www.sau.com.au/forums/topic/47721-beyond-10-bar/#findComment-963097
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
