Hi all, so I'v done a rb20de+t neo conversion in my r33, if opted with the rb25de loom 25de intake, with a rb25de cas, it was going 1 day, I ran outr gas the next now it will crank over but wont start,, I have spark and fuel, maybe thinking my cam angle sensor is dead,,, I'm in the middle of sourcing a new 1 but was told a normal rb25de cas can not work on a neo engine,,, help help bit stuck. Thanks for your time to read and maybe help a brother out.....
https://www.sau.com.au/forums/topic/477236-r33-rb20det-neo-conversion/
You'll need a CAS that suits the exhaust cam as the spline on the exhaust cam is different on the neo compared to a S1 or S2 rb25. If you're using the rb25de loom/ecu you'll then need to flip the two end wires of the CAS plug. I assume you would have already done this if the car has been running?
What made you think the CAS died?
Edited by jmknights93
Just to be clear have you had this car driving properly or did the engine just fire once then die? You have the right ECU? You have fuel but is it enough - have you checked the pressure? You ran out of gas is there dirt in the system? Have you taken the CAS off to see if it spins freely?
Yes I'm using a rb25det manual ecu, yes cas spins freely,,, I'm assuming theres enough gas getting thru, iv had it runing for months then suddenly ran outr gas and hasnt start since, engine turns over fine,,, just the 1 day I put my drive shaft and and manual conversion in and wont blaaaardy start,
OK so have you had it running in manual mode? You have shorted out the fuses under the battery (to disable the lock out that stops it starting in anything but P and N)?
8 hours ago, Deangelo said:
I was low on gas (I no dumb) and was working on my car had it running and cut out,,  but what's your thoughts?? All thoughts on this is more than welcome thanks,
i get the feeling there are more things going on that we dont know about. the likelihood of the cas failing at the same time as the "running out of fuel" incident doesnt make sense.
both above posts are quite relevent
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
