  • 1 month later...
16 hours ago, ActionDan said:
Looks amazing. Keep a good layer of your preferred sealant on it, boy do reds love to fade lol
definitely going to protect is as much as I can lol.  Gettin the main dash painted to match and then bolting up all the carbon fiber pieces.
51 minutes ago, ActionDan said:
You're painting the dash? Which parts?
basically the whole main dash itself.  i have a carbon fiber glove box, carbon fiber radio bezel down through the entire center console, the steering surround, and the gauge cluster surround.  I also have a sheet metal rear seat delete and sheet metal door cards that I am going to have hydro dipped carbon fiber to match as close as I can.
2 minutes ago, ActionDan said:
so what colour are you poainting the dash itself?
red to match the car.  I just got a truck from someone that has a paint matched dash and I love it so I am going to do the same to the skyline.  only way to really "modernize" the dash so the interior doesnt look so dated.
Well, it's not my style, but it's your car and you've got to love it.
If re-sale matters to you, I would strongly suggest not doing that particular mod, but if that's not a concern, go wild and enjoy it :D
  • Like 1
I will be buried in this thing at this point.  There is way too much money wrapped up in it to ever bother selling it.  When I say ground up, I mean ground up.  There's not many parts or pieces that havent been upgraded or replaced with new oem parts.  It will basically be a brand new car that I plan on driving every damn day! haha
  • Like 1
1 minute ago, K_arlstrom said:
Bold move! Need to see how it ends up
follow the build.  now that it will be back at my house tomorrow, I get to really start digging into it and putting it all back together!
15 minutes ago, K_arlstrom said:
Will do! I'm two steps behind you but probably close to 45k AUD deep into my rebuild... Always a comfort to see someone else go all out too ?
Im almost 75k USD into mine so far but Im about all in. Not much left to buy at this point.  Its all piled up in my basement ready to go.
Best type of insanity! My worst fear at the moment is that my car will get too good, that the driving will feel dull since I can't use its potential.
Oh well, back to topic, this is your thread after all! You went with a trigger kit, s13 subframe and newer color. Got any other modification to share with the rest of us? Found the thing that will make it truly your car? (maybe the dash?)
Better than drugs right?!  I also went drive by wire with a 350z pedal and a ctsv throttle body.  Going full air suspension and all gktech adjustable arms.  Shaved door handles and trunk lock.  Trying to go neo power steering pump to get rid of the dual stage pump, hopefully I can get that to work.  Engine was rebuilt.  New gaskets, rings, and seals.  Poncams and adjustable pulleys.  Cant think of anything else thats too crazy lol.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
