WTS:
OPEN TO OFFERS - Just want the stuff gone
WILL POST AT BUYERS EXPENSE
****RB30/Engine Bay Parts****
S1/2 Coils x4 $15 each
Throttle body x2 $20 each
Auto ECU covers $5
S1/2 Air box lid $10
****Outside Parts****
S3 Passenger Side headlight $30
S1/2 Bonnet - Needs repaint - In primer $30
S1/2 Passenger side Gaurd $30
S1/2 Filler Pannel $20
Drivers Side mirror - Has broken tabs $10
S2 Skyline Grill $30
Horns x2 $10 each
S1/2 Tail light middle trim $5
S1/2 Rear boot garnish. missing all screws $5
Stock R14 rims with non RCW tires x2 $10 each
Front Swaybar - factory $30
****Interior Parts****
Ash tray - $5
Random S1/2 grey dash buttons $15 Each
Random S3 Black Dash Buttons $15 Each
Dash Clock $10
S1/2 Dash surround - No buttons or Vents $15
S1/2 Dash surround - With Buttons and Vents $40
Wiper stork Non Adjuster $15
S3 Radio Surround with Nissan Badge - $10
4 Gauge cluster $30 Each I have a few
S1/2 Centre light wiring loom $10
Steering wheel surround $15
Window winders - Brown $5 each
Window Winder backing circles - Light brown and Brown $2 each
Interior Door handle surrounds - Light brown and Brown $5 each
Brown Vinyl Roof liner $20
Brown wagon Side roof trims $20 for both
Brown Glove box x2 left $15 Each
Brown sun Visors: Drivers side x3 Passenger side x2 $10 each
Carpeted Kick Pannels $10 each
Air Con A/c interior unit(Sits under the dash, next to the heater)$20
Air Con A/C Rad fan $15
Brown GX Drivers Seat $15
Brown GXE Passenger seat $20
Black Painted Dash $80
https://www.sau.com.au/forums/topic/477253-r31-skyline-rb30-parts-clearout/
  • 1 year later...
  • 3 weeks later...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
