 Hi all.
I am doin a complete 33gtr engine n gearbox swap into s1 stagea (will keeping it standard) and I've come across a big problem.
I've got all engine to ECU wiring looms for the rb26.
When I took out the stagea engine to ECU loom out I did not release that the 2 small plugs are completely different to the rb26 engine to ECU loom.
The big plug I know goes to the ECU it's the 2 smaller plugs I dont no what they do.
Has anyone on here done this complete swap n if so how did you get around the loom plugs and how did you find out what plug dose wst and what wire is wat even tho the wire colours are different between the 2 looms.
This is the only thing yhsy is holding me back from completing the swap over.
Thanks.
So I think the posts above kind of cover it....while mechanically the swap might not be too tricky, the engine loom is different between R33 GTR and Stagea and you are going to need to merge the GTR one into the stagea.
Basically, take the stagea , translate it, manual pin out, take the GTR loom and it's pin out, and follow to the plugs (other than the ones on the engine).  You need the other side of each stagea plug (or cut them of both looms and replace with something with the right number of pins) and join each onto the right wire in the GTR loom.
Possibly a bigger job than the mechanical side unfortunately.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
