Excessive torque is what chips teeth off of meshed gears. That can be a direct effect from simply giving it way more than it can handle, or it can be a cumulative thing where the shaft bearings cop a flogging over time and then allow the shafts to move apart and load the gear teeth incorrectly. It can also happen where the case can't take the torque loads, deforms and allows shit to move to new and unexpected positions wrt each other.
Hamfisted shifting is what strips teeth off of synchros.
On 6/4/2019 at 6:44 PM, mlr said:
My old boat with 700nm and drag radials would kill a box to quick.
It basically chewed the surface off the gears turning the gearboxs into a screaming banshee
Than might have been a lubrication issue. What oil & how old? IIRC the guy from Award used to have a mod to help stop oil slopping to the back of the gearbox.
Or if the gears are case hardened perhaps the case hardening was worn through exposing the softer material underneath.
Award built one after the car ate the original, with that oil mod thingie award does.
After that one was eaten they built another, that lasted a month or so, then after a run down the stip, that one started to whine.
Award said the OEM gears just weren't up to the level of torque.
I found the torque rating for the box ages ago but I cannot recall what it was exactly, it was nowhere near 700nm though.
They recommened some brand of gears which were well out of my price range at the time, IIRC it was going to be $20k or something all up.
I sold the car at that point, it was to expensive to keep thrashing, one of the next owners put in that dog box.
It's a auto now though, doing roll racing at Eastern Creek.
  • Like 1
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
