Originally posted by WASSABI
just wondering if anyone knows, when the pump was installed the old one seemed to just be sitting in the tank not attached in anyway, so the new one just got plonked back in not attached... does this sound right?
GTR pumps sit into a plastic baffle/swirl pot type thing that clips into a bracket in the bottom of the tank.
If yours in floating around ,it's prolly vibrating against the bottom .
Ken
https://www.sau.com.au/forums/topic/4773-gtr-pump/#findComment-74904
Hehehe get cypher to 'fix' it? riiiiite
Umm, just make sure they have a direct line to your bank account.
Actually when you go in there ask them about the red pintara station wagon that ran out a fuel, and then ask them why, if they dont know why, i wouldnt be getting them to 'fix' the problem.
DISCLAIMER : These are the words and opinion of RB20LagWagon (Sean Williams) and no the opinion or words of forums.skylinesaustralia.com
Have a nice day ;)
https://www.sau.com.au/forums/topic/4773-gtr-pump/#findComment-75097
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
