hey guys, im a new member to this forum
ive owned my r34 skyline (non turbo) for about 4 years now and since im off my p plates i want to turbo it now.
i cant be bothered selling it and then going through the hassle of looking for r34 gtt id much rather build up what i got now.
so i was wondering does anyone know any mechanics or someone who sells and/or installs turbo kits for skylines.
preferably somewhere located in the western suburbs of Melbourne.
any help/advice would be much appreciated
thanks, ?
The standard advice around here is to not do it. More pain and expense than it is worth.
There is no such thing as a "kit". You can try to scrape together the minimum things you will need to make it happen, which is;
  • Turbo + manifold,
  • exhaust,
  • intercooler,
  • injectors
  • fuel pump.
Oh, and an ECU, because the pain inherent in trying to make a GTT ECU run on a hacked together mishmash of things with some missing/wrong sensors etc etc is not worth it. Aftermarket ECU simplifies life.
But that ignores that you will destroy the clutch and so will need one of them. And the gearbox won't last too long either, so you really should put a big one in. And the open diff will have its own float in the Mardis Gras, and the front brakes will need upgrading.....and you're in Melbourne, so adding a turbo is like totally illegal without full engineering, so add that if you want your insurance to work.
What he said^^^
Selling your n/a and buying a GTT is a walk in the park compared to converting your current car. Its time to say goodbye...pass your car on to a P plater and get yourself a turbo model.
thanks for your advice.
in my original post i preferred to turbo what i got now, dont have much interest in selling then buying a gtt model. so im willing to go through the hassle of what it will take to convert it to a turbo.
ive heard its easier to just install the stock factory turbo that comes off the gtt model.
in regards to what i need like turbo, manifold, exhaust and those sorts of things my best bet is to find them online/ebay?
my r34 is the GTV model so i believe its got the diff and brakes necessary for a turbo conversion.
i know someone who can possibly engineer it properly should there be any problems with it being illegal to do.
On 07/06/2019 at 6:36 PM, Ben C34 said:
To turbo a car that is available turbo is silly.
LS swap it, then turbo that.
id think about putting a LS if i were to track it but because it would be for street use i want to keep it RB
On 07/06/2019 at 7:30 PM, Dose Pipe Sutututu said:
LS so 2010, Barra swap it. 500kW stock motor with just head studs, valve springs and a billet oil pump gear.
A RB can only dream.
i prefer to keep it RB
  • Like 1
so i have been thinking.
would it be best to save a bit of extra cash and sell what i have but instead of buying a GTT id just buy something else.
i would love to get a r32 gtr or evo 8/9
anyone know of any good import companies i hear iron chef imports are good.
anyone got any other suggestions on which import company they trust that are good?
It can be done!
You wanna do it. Learn . Accomplish.
https://www.sau.com.au/forums/topic/466795-doing-a-t-conversion-on-an-unopened-rb25de-neo-r34-gt/
Research is the begining.
Best kit is a loom ,ecu ,drive train and pump swap from a gtt.
11 minutes ago, Slap said:
It can be done!
thanks!
  • Like 1
https://www.sau.com.au/forums/applications/tapatalk/index.php?/topic/426222-If-You're-Happy-With-Your-Import-Car,-Who-Brought-It-In?
If You're Happy With Your Import Car, Who Brought It In?
These 2 are incompatible. The only people who should consider buying R32 GTRs at this point in history are those who simply do not need to "save a bit of extra cash". You have to budget on spending the purchase price of the car every 2 - 3 years just to keep the bloody things running.
Follow your heart , sacrifice the essential.
If you can pimp it... pimp it.
If you can sell and buy closer to your heart do it.
If ya want all of em collect and save.
If ya want fast get or make somthin fast.
I can only tell you what i did not tell you what or where you wanna buy.
I saved some money up
My r32 skidline was brought second hand in 2011 from Port Macquarie nsw off a fella called brad. He had old scool mods wich i learned to hack and make use of at the same time keeping it unique. Even had neons in the engine. I had to fix all the weak links in the chain of mods nothing drastic. He did a great budget job for back in the day. Cost me 3k had Porsche gt green with black graphic center stripe , looked cool but road worthy inspections were refused at multiple places untill it was painted.
So i learned to paint.
Wouldnt let it go ever now passing it down to a son (lucky bugger).
So good luck im sure you will find one but they are usualy 10-15k gtst and gts4 or 30k+ gtr
301880739_images20(4).jpeg.1a848f930f13ba7e640f874da70483db.jpeg20171210_175405.thumb.jpeg.63719fb43c33a63370528191ded86295.jpeg
"I can only tell you what i did not tell you what or where you wanna buy."
Not being interested in an engine/halfcut swap makes as much sense as the quoted sentence from the above post.
  • Haha 1
How does that make no sense.
Oh wait your post makes no sense.
My views of not buying a turbo car, and then putting a turbo on a non-turbo'd car, but also not using a half cut, from the same model of car of your non-turbo'd car, that came with a turbo, is like "I can only tell you what i did not tell you what or where you wanna buy."
That should clear things up nicely.......
  • Like 2
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
