I’m wanting to increase the power slowly of a period of time bit by bit
my question is are there any issues running a 1000hp  fuel pressure regulator on stock boost and lines
just so it’s installed and sitting there then the build can work around it
https://www.sau.com.au/forums/topic/477374-info-required/
A regulator that can handle 1000HP worth of fuel has a very large flow passage in it. When you try to run it with a smaller pump at much lower power levels, the regulator's valve might end up running very close to the seat in order to maintain the pressure setting and this can lead to unstable pressure control. If the mismatch is severe enough the valve will have to close to get the pressure up, then it will have to burp open because the closed valve is not regulating pressure, it's just allowing it to rise. So instead of a steady servo-controlled pressure, you get a nasty saw-tooth pressure.
https://www.sau.com.au/forums/topic/477374-info-required/#findComment-7908073
It's really more a question of how big the fuel pump is, not the amount of power the engine makes. The limiting case is when you are making near full power and using almost all the fuel pump capacity. In that case the reg is going to need to be very nearly closed to keep pressure control, possibly leading to the sawtooth I described above. That same engine and pump, at idle or crusing, is going to need to return a lot of fuel back to the tank, so the reg will be more open and pressure control will probably be fine.
The capacity of the reg is 100% a function of the capacity of the fuel pump. If the fuel pump is a decent size, you'll probably be OK. If the fuel pump is gasping at your 350 whp, then it might not be so rosy. Very hard to say without trying it.
If your pump has higher capacity than stock, then more than likely it will be fine. But no warranty is issued or implied!
  • Like 1
https://www.sau.com.au/forums/topic/477374-info-required/#findComment-7908108
if base pressure is 38psi will be ok running a reg that has min of  40psi adjustment? ie a 40-75psi reg?
https://www.sau.com.au/forums/topic/477374-info-required/#findComment-7908154
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
