Used complete set Fullrace RB26 Twin Turbo EFR7163 for sale.
- Turbo manifold and downpipe done Ceramic coating 2000 degree silver colour.
- Upgrade to turbosmart actuator and turbosmart bov cover.
- use for 2000 km only. Seldom drive the car.
- make 1.8bar 750rwhp on dynojet ( pump gas 97 )
- pristine condition.
This set turbo buy new from Fullrace is 7299 usd plus shipping. Add another 900 usd for upgrade turbosmart. total price 8199 usd.
Now selling 5600 usd include shipping.
My loss, your gain.
Serious buyer only. Item is very heavy, shipping charges can cost me easily for 600 usd.
Contact number 0168398739 whatsapp.
Thank you
  • 3 weeks later...
  • 1 month later...
  • 3 months later...
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
