Hello,
I have searched the forum and multiple parts stores and have yet to find a factory replacement for rb20det fuel injectors. I have no interest in upgrading to the GTR injectors because I do not have any Intention of tuning the car. It seems like keeping a Gtst stock and clean is one of the hardest things to do with these cars.
Does anyone one have any viable options for replacing injectors without requiring any tuning. I recently had 2 of them clog while I was living in Japan and was able to get them cleaned at a performance shop. I regretfully did not ask if they had spares. But I am hoping to get my hands on a few before i have any issues with the rest of them.
https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
17 hours ago, GTSBoy said:
This is one of those situations where I would just Nistune the ECU and put in some Bosch ID14 based injectors. The car will 11ty times better afterwards. Staying stock just for the "niceness" factor is a bad idea when the niceness really doesn't exist except in your mind.
The car only has 50k kilometers and is in near mint condition. I want to keep it stock for the drivability factor, it handles and performs pretty damn well for a 27 year old car. If I wanted to modify I would have started with a better platform like the GTR or an rb25 car.
With that being said, Nistune has always been an option but I have not been able to verify whether or not the Nistune type 2 board will solve the problem on its own. My understanding is that a Nistune will come with a base map but in order for the car to run any better than stock, if not worse, it will require a tune. I am living in Europe at the moment, there are very few shops that deal with Nistune.
Nistune is literally just a daughterboard on top of the stock ECU that allows you to edit values in memory in real time and read values in memory.
Nistune's base map should be the stock ECU map. I would be shocked if it were anything else.
I understand your desire to keep things stock to have good street driveability. The best way to do that is to find the most modern, split spray, high atomization injectors that will fit the stock fuel rail + intake with appropriate sizing for your power needs.
http://www.nzefi.com/product/nissan-rb-440ccmin-top-feed-direct-fit-fuel-injector-kit/
Something like these Bosch 440ccs will likely have better atomization than stock for better driveability. The factory injectors are old tech and have poor spray pattern + atomization. All you have to do to retune is input the fuel injector data into Nistune with the base map, disable the O2 sensor, and check on the dyno that your AFRs for idle, cruise, and WOT are what you expect. If you just want stock performance you're done after that.
1 minute ago, GTSBoy said:
^ This. all of this.
Keep the stock injectors in a box for the "can return it to stock but never will because it would be a real backward step" warm and fuzzy feeling if you want.
i keep it stock or nearly stock because i like consistency. This car never had any surprises and i trust it to rev to the moon and back and never skip a beat, which it does daily. My previous RB cars, and other RB cars I've worked on, have never been the same once aftermarket parts started getting thrown on for the sake of performance. If trying to stay stock or as near stock as possible is for losers then I'll take that L with pride while i drive this car to 250k miles for the next 20 years.
Thank you though for the input, and the link for those Bosch injectors. luckily they're all working just fine right now. If one of them fails and cleaning it isn't an option then i guess i'll have to bite the bullet and drop 2 grand on injectors, Nistune and dyno time ?‍♂️
I do agree that a healthy dose of skepticism for aftermarket parts is a good thing, I think for a long time the default attitude was that aftermarket everything is best. But if you do your research you can find things that will be an actual upgrade and won't cost you in reliability. The 440cc Bosch injectors were originally designed for OEM applications in the early 2000s which means more stringent emissions requirements and reliability requirements due to longer emissions warranties.
i would go ahead and swap them on now if i knew the car would run with them, unfortunately i know thats not the case without a tune. i installed a blow off valve on a cefiro once and the car went into limp mode, come to find out the rb20's take into account the surge of air in the factory recirculation system. it amazes me how sophisticated these cars were for the 90's. but it has its trade offs.
That isn't at all sophisticated if you look at how an afm functions. Definitely nothing to be amazed by.
You don’t think it’s a little arrogant to say that it wasn’t an impressive feat for a 1980’s design on a entry level sports car? Handling multiple parameters, when the rest of the world was still saying goodbye to carburetors.
I mean I understand how The wheel works too but it’s still pretty amazing that someone who didn’t wear pants was able to make one out of a rock a few thousand years ago.
Just now, Ben C34 said:
But it is by nature of the plumbing that it works, not some kind of genius invention. It is dead obvious, just like a wheel!
Oh boy...
do you have any info on injectors that won’t require a tune? ?
Just now, GTSBoy said:
Jesus. I put a Nistune into my Rb20 ECU and then into my Neo ECU and both those engines still have stock injectors. Tune = good. Not bad.
My old laurel had Nistune installed before I bought it, it’s a great system, and it’s cheaper than a full standalone. I understand what it does and it’s benefits, especially for a street car.
You’ve made your point. Thank you. I’m just seeing if anyone out there has ever found a replacement for the stock injectors. It seems like the answer is no. So as I said before, I guess I will have to suck it up and Upgrade my ECU for something silly like a bad injector when the time comes.
Tuning isn't rocket science. Changing injectors is dead simple, especially if you have the "feature pack" ROM for Nistune that allows for injector scaling without affecting the load scale. Matt seems to be pretty friendly to helping people out with simple jobs like this: http://forum.nistune.com/viewtopic.php?t=2656
Edited by joshuaho96
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
