Hey all, new to gtr's here. Just got my R32 gtr not too long ago. Rebuilt the motor over something like 4 months and got it back in the car and been fixing small things here and there.
The issue I'm currently having is the harness that goes back to the trans and plug into reverse switch, and other plug down there, got caught in the front driveshaft and torn off (my own stupidity for not securing it) after putting in a new harness. My reverse lights are constantly on, the right rear blinker stopped working(tried bulb in left rear and works), and also all the speakers on the right side don't work. The question is are the blinker and speaker circuits somehow related to that harness underneath? Any tips on where to look first?
Thanks in advanced.
https://www.sau.com.au/forums/topic/477409-odd-electrical-issue/
Not related. Separate issues. Standard electrical wiring troubleshooting required. Find the power source on the wiring diagram, find the earth, find the switch. Work out where the pixies can't* squeeze through any more.
*Or in the case of the reverse switch, that the switch was probably damaged when you yanked on the wiring and it is now stuck on/shorted.
Edited by GTSBoy
I agree. I don't believe these would be related.
Without a wiring diagram, you'll need to trace the wires in their entirity. Start with the fuses.
Possibly something has shorted at your battery or fuse box. If not check all the way down the wiring and make sure to check and clean earthing points just in case.
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
