I'm at a quandry, and am seeking knowledge from the brains trust.
My car won't take timing while trying to tune, all it does is ping its tits off, initial thought was intake or exhaust restrictions but they've since been disproven, as it's got a 3" system front to rear, brand new 100cell cat, and magnaflow 3" inlet 2x2.25 outlet see through muffler, a k+N panel filter etc.
Nistune ecu, injectors as well are within range and not running out (725cc), plenty of spark with Audi R8 coils and fuel pump delivering ample supply/pressure, intercooler has been changed to a higher flowing water to air unit with much shorter piping, engine has good compression and seems to be feeling healthy and wanting to be fed more, yet something is holding it back and it won't take timing, so am left scratching my head as to what the hell is putting the blockers on.....
Any ideas at this point would be gratefully received
https://www.sau.com.au/forums/topic/477442-ideas-why-engine-wont-take-timing/
33 minutes ago, Duncan said:
Is it a new engine, or are you trying to tune an engine that has been running OK on a standard ECU. If the former there are plenty of things that could be done wrong causing an issue
It's an engine that's been running fine and smooth, was rebuilt supposedly with forged pistons etc about 10-12000kilometres before I got car, and has kinda always felt doughy in the mid range, even with high flow hypergear it doesn't really come on boost until about 3500rpm
This is possibly monumentally off topic, but I recently was made aware of a similar issue where a Boosted 1979 BMW 320i was pinging its brains out on like 3deg of timing. After years of living with it we tested the FPR (Which was a well known australian brand) and it was dumping a good liter a minute of fuel into the intake at idle through the vac line.
It's probably not that. But if you've checked everything else.....
(it could also be as mentioned, something done when engine was rebuilt. If your car behaves differently, look for all the things that are done differently to others)
Car doesn't seem to be excessive on fuel consumption so hesitant to think it's dumping fuel in, though have just installed a new adjustable reg, and 300lph pump compatible with E85, so we can test that theory once car is done with installation of flex fuel stuff.
Have had 2 jdm enthusiast /specialized mechanics looking at it and it's got them scratching their heads as to why its like it is, they've both worked on it separately as well as together and short of removing and peeling engine open we've started to make incremental changes to parts, then test and if no change try something else, change, test and so on
The BMW mentioned also wasn't bad on fuel, but it did have a mysterious issue of always fouling two spark plugs, due to the location of the runners this made a whole lot of sense when we looked at the FPR. It could simply be something like the wrong pistons used, sky high compression ratio etc too.
E85 will help with the pinging, but obviously better to find the source ?
What would be the differences if any between rb25det pistons and rb25det Neo pistons? Anybody aware of what issues they could cause with clearances etc
Pretty huge. If you had Non-neo forged Pistons in a Neo motor, I.e R33 RB25DET pistons in a R34 RB25DET Neo which the S2 Stagea has, your compression would be massively high.
High enough that whoever assembled the motor would surely notice...... surely....
It might be the other way around, I can't quite remember. But you'd definitely have compression ratio issues if the wrong pistons end up in the wrong block/head combination. (neo vs non neo)
I have the build sheet for engine, and sadly all It says is forged rb25det piston kit, but no part number to identify if it's neo or otherwise, so will do a compression test and check figures I spose, apparently std comp is about 170-175psi range, I'll also attempt to call the engine builder and see if they can remember what they were, though it was around 3 years ago so don't hold much hope
I would have the injectors checked for flow just to rule that out.
And might not be but the vct gear could be playing up, that can do odd things, might be too advanced (the slots at the back).
Edited by AngryRB
Have spoken to engine builder, and they can only vaguely remember what piston they used in engine, said they reckon it was a modified wiseco piston, so my thought is that next steps are comp test to see if excessive, and the throw E85 at it and see what it does from there.
Then if that fails yank it out, peel it open and put a proper f**king set of neo piston in it just to be certain
Brand new bosch 725cc from efi solutions and no sign of running out of room for flow, and have just got new pump and adjustable reg fitted ready for E85
So, it sounds like it's been running, but wrong, all along. Poor midrange suggests it couldn't take timing back when they first tuned it either.
Start with the easy stuff like ensuring the timing is all OK. Check timing with a light obviously, but also check TDC is correct on the balancer (skidfactory did a good video on checking this), then check the cam gears are correct and not adjustable, and then check the timing belt is not a tooth or 2 out.  All that you can do without pulling the engine apart.
I'll see if the vct bits have been sussed out, new timing belt and adjusters fitted in last couple of weeks to ensure it hadn't been skipped a tooth on pulleys etc, did ask if the bull nose bit on front of cam was free and clean and all reports were it looked fine by them.
When you say slots in back, do you mean on the bull nose bit or the cam itself?
New balancer is being fitted already as old one was getting tired and perished, will then try timing light etc, cam gears are std OEM stuff, and new belt was fitted couple weeks ago whilst it was opened up to check it hadn't skipped a tooth or 9.
Currently waiting for the ecu to return from Nistune after having E85 harness fitted and a general checkover found nothing out of the ordinary
On mine though they are fairly advanced and i dont have pinging issues on E85, i do have high comp though. Just somthing to consider.
Edited by AngryRB
What was the previous intercooler setup and are you sure the new one is more efficient? Do have iat readings?
Is the intake tract and cooler piping internally clean or is there oily residue from blowby, excessive blowby can also cause pinging if substantial enough. Catch can can help here.
As already stated e85 will help mask the issue but better to be sorted properly.
well, assuming you trust the guys that did the timing, I think your engine has a mechanical issue like wrong pistons, or decked block and head. So either you make the best of what it does take, or pull it down and check....
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
