Hey, alright so I can't seem to find any help on this issue anyway so I thought I'd ask here.
I have a aftermarket headunit (Kenwood ddx4) in my skyline r34. When I chose the radio mode on the headunit all I get is static.
I've heard it's because it's from Japan so the frequencys or something are different...Im honestly not sure why it's not working.
Is there a way to fix this so I can listen to radio channels ??
https://www.sau.com.au/forums/topic/477451-r34-radio-fix-aftermarket-headunit/
If the radio came from Japan *(installed in the car already) then the frequency band will be out.
If it is an Australian radio it shouldn't be an issue.
Assuming you have an Australian radio check that the antenna is connected to the head unit properly (it just pushes in). Air gaps in RF systems aren't normally helpful. Make sure the cable hasn't been damaged or cut anywhere.
An antenna cable that has been crushed is as good as useless as it will be creating an RF short, thereby meaning no signal will run the full length of the cable. Check the antenna cable for damage.
Thank you,
It is an Australian headunit and after some searching on other forums I found that window tint effects the antenna.
So I've bought an aftermarket antenna and will test fit it tomorrow to see if that fixes the problem.
I'm glad you found this info... never occurred to me. [emoji848]
I was going to suggest using an FM transmitter and see if the radio works when your transmitting from in the car.
Come back if your new antenna doesn't work. Happy to keep throwing ideas at you. [emoji16]
My 34 had the active rear speakers and I recall having to choose between powering the factory speaker amp or the radio reception amplifier with the blue trigger lead from the head unit. May be worth checking. Took me a while to find the right info too and I don't remember where I located it
Hey everyone, the aftermarket antenna fixed the problem [emoji108] thanks everyone for your help.
Glad to hear it all worked out. You know where we are if you ever need help. [emoji16][emoji106]
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
