Hi guys building a r33 gtr was completely stock when purchased due to be completed within 2 weeks looking for a good tuner who does everyone recommend ? I’ve narrowed it down to birrong and Croydon open to others this is my  list mods include -9 turbos gtss x force dumps, tomei mainfold, hks front pipe, hks hard intake pipping kit, hks fuel rail, 800cc sard injectors,tomei fuel reg, Walbro 450l fuel pump, catch can, Apexi cat, tomei adjustable cams, haltech platinum pro ecu. I am chasing 330-350kw on pump fuel 98 I think this realistic I guess the turbos are the limiting factor here
https://www.sau.com.au/forums/topic/477459-gtr-tuning-build-advise/
Expand
Is this the list you are thinking of getting or what is already installed?
  On 20/06/2019 at 6:19 AM, Leroy Peterson said:
Sounds like a solid wishlist from 2002 so probably already installed?
Expand
Expand
It’s whats currently being installed at the mechanics at the moment, I know it’s a old school set up but I wanted to keep it low mount set up and twin turbo and I’ll be happy if it’s around near 350atkw
  • Like 2
Internet rumours, anyhow that's personal preference.
With what you have you'll get a healthy 320 to 330kW, maybe a bit more depending how much timing your tuner puts in.
Replace that Jap crap cat with a venom 5" inch body one, more flow means more power and the ability for the motor to accept more timing.
The thing about old school setups with old school fuel and old school items is...
... they're tried and tested, and work. Even if they aren't the worlds greatest result, they work, and will continue to do so. 320kw bolt on package in a GTR is plenty to have fun with, day in, day out, enjoy car etc.
  • Like 1
Hey Mate,
I have a very similar setup as you as looking to have fitted up.  I've running twin HKS GTRS (dash 10's, which are super laggy) plus 1000cc injectors, platinum pro, HKS EVC, NISMO intercooler, E85 fuel lines, external surge with twin 404's, plasmaman fuel rail and Tomei pon cams and cam gear.
I probably wouldn't go the Tomei manifold unless it's the cast model.  The stainless has a tendency to crack (which mine has) and then can play around with startup idle from time to time.  Plus I don't think that there is actually that big a gain over the standard manifolds.
I've running duel mapping for 98 and E85.  On 98 I'm making 305RWKW (at 19psi) and on E85 405RWKW (at 27psi).  Since you're running the Platinum Pro it can't hurt to have both E85 and 98 maps setup anyway.  It's then your decision whether you use E85 or 98 but at least you have the option.
All my tuning work has been done by Adam and the boys at JEM and I can't fault their workmanship and expertise when it came working on and tuning my GTR.
The setup isn't for everyone's taste, as most on the response, however, I like you I wanted it setup similar to the way it would have been done back in the day.
Where abouts in Sydney are you?
I've had multiple cars inspected, worked on, tuned and troubleshooted including my R34 with -9s and supporting mods on power FC at MRC in Seven Hills in western sydney and very happy with his work, feedback and attitude towards tuning.  Have been back several times for other mods and troubleshooting and am happy to have found a good one-stop-shop in Mark.
  On 26/06/2019 at 5:54 AM, BlueThirtyFour said:
Hey Mate,
Expand
Hey mate thanks for sharing we have close setups, I’ve actually been doing a bit of reaserch on JEM they have very good reputation from what I can see Adam seems like a good guy and at this stage he the number one pick. Would you change to -9 if the -10 is that laggy ? I was very close to getting the -5 but after looking at reviews I wanted more responsiveness
Expand
Ok I’ll probalby have a chat with them for sure what power did you get out of the -9?
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
