This car represents great value at $24,500.
I'm not looking for swaps or time wasters.
Contact: 0408257613
I've moved onto different hobbies and the car rarely gets driven, as you can see by the amount of KM I have put onto it since importing.
Located Canberra, currently registered however will need to go over pits for the name change.
I have the stock exhaust to help with this.
YEAR: 2000
MODEL: SERIES 2
COLOUR: Pearl White (rare)
KM: 138,000KM (Imported with 97,000)
INFO:
I'm the first and only Australian owner, the car was imported through Iron Chef Imports in 2013, with only 97,000km, Grade 4B. Stock sleeper look, nothing flash in the engine bay. Regularly serviced by Import Parts and Mechanical Canberra. Unfortunately, no service log book as originally the servicing was done by myself and mechanic friend.
TUNE:
Full flex tune thanks to DVS Tuning Newcastle
E85 power output: 287rwkw
Pump 98 power output: 255rwkw
Boost 20PSI and tapers to 16PSI
HEART:
Adaptronic ECU
Manifold air temp sensor (nice and safe)
MAP sensor tuned (nice and safe)
Hypergear ART45SAT turbo
Zeiotronix flex fuel gauge
Flex sensor
NPC HD Organic Clutch (rated to 350rwkw)
FUEL SYSTEM:
Walbro 255 E85 fuel pump
1000cc E85 rated Bosch injectors
Aeroflow micron fuel filter (suited to E85)
Splitfire coilpacks
EXHAUST/INTAKE/COOLING:
3inch, with mufflers and high flow cat
Blitz return flow intercooler (legal no holes cut)
Apexi Power Intake Panel Filter
Turbosmart Kompact Plumb Back Blow Off Valve
Thick Alloy Radiator
WHEELS/SUSPENSION:
Varrstoen ES2 rims (very nice stance)
Federal 595 tyres
Rear MCA blue coilovers (brand new set ready to go in the front)
Front HKS coilovers
OTHER:
Xenon headlights (expensive and rare)
Aftermarket front bar with air vents
Imobaliser and alarm system
DAMAGE etc:
Few scratches and the classic gravel chips on the front bar
Dint on the bonnet as seen in the picture, not substantial.
Rims have gutter rash
Tyres are worn and should be replaced
Classic wear on the side of drivers seat as seen in the picture
Wear on the gear shifter
Timing belt is whiny sometimes, however was replaced at 100,000km
EXTRAS NOT INSTALLED - you can have these with the sale:
Original series 2 front bar
Original stock exhaust
Original reo bar
Original intercooler
Front strut brace
New magnaflow muffler
Oil temp, oil pressure and water temp sensors/gauges
HID kit (will perfectly compliment the Xenon headlights)
Wideband 02 sensor (will perfectly compliment the tune)
After looking more into the current market and prices, I'm going to be dropping the price down to $22,000
The original price of $24,500 probably was a bit outside of what they seem to be currently going for.
Open to offers, just not swaps.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
