Please hear me out:
I ordered an R35 coil and bracket kit along with a custom harness. I'd like to keep the companies nameless for now (coils and bracket kit was separate from the custom coil harness).
I installed the kit following the instructions to the last letter. When I tried to start it, there was no spark. A little searching and found a simple mistake. The custom harness had the three wire plug with the power and ground wires switched. I flipped them and I then had spark. HOWEVER it ran like garbage. Hesitated to start, idle was rough, and it died as soon as I applied any but of the clutch. It acted as if it were rich. The brand new plugs were fouled. I added a picture of one of the. That is with less than 3 minutes of running.
I contacted the company and they sent me a replacement harness but it still ran like garbage.
I then checked that I had proper connection with the plugs and new coils. The spring in the custom stalks were the correct length and as the plug was pushed in, the spring moved. The resistors are also in place and making contact. Both of the other connectors were secure along with the ground. Even replaced the R35 coils with another set of brand new ones.
I pulled the kit and put the OEM ignition back in. It started up no problem. But it wasn't until tonight that I tried to drive it. It now acts the same as it did with the R35 coil kit. I couldn't even drive it out of the garage without it falling flat on its face. Smokes like it's rich, new plugs again fouled and now won't start. It spits and sputters but dies right away.
When I started this whole thing, it was fine! No problems. It has been on 2 long trips with in the past 2 months. I only went this route as the clips were brittle and decided to upgrade.
I do not understand what happened!
Ignition timing was not changed either. I also switched out an known good ignitor and still no change.
Is there a chance the power/ground wires switched in that harness messed with the ecu?
Did you add more dwell? OEM is like 1.9ms at 14v, you need close to 4ms to get them to work.
I have 3.8ms at 14v with mine, runs so much nicer than the Splitfire with a boss 1.1mm gap and at present 1.4bar of boost.
I just noticed I put this in the wrong category. My appologies.
I didn't. By the way, this is an R32 GTR almost all stock. Only the HKS filters and 3 inch exhaust. Stock ecu. So no adjustments possible. And I reached out to the company and they said it should be fine.
But that also would not explain why it still does it on the stock coils and ignitor.
I would check the OEM earth points on the ECU (inside), check the voltage going to it and comb through and see if all the OEM earth straps are connected from body to motor.
Using a multimeter, check the loom on the coilpack. Say your electrical system measures 13.8 to 14.4 whilst running, when you measure the voltage at the loom it also must be close to that, yes there may be a slight voltage drop but that's normal.
I did exactly that. Checked grounds and started to trace wires. But before I go too far into that, the ecu was right there. Easy work first. And this is what I found!
Can anyone identify the board?20190625_152532.jpegSnapchat-1801368067.jpeg20190625_153222.jpeg
so....the earth wire was switched with the power wire in the loom you bought, and now the ECU is fried. Perhaps talk to the people that made the loom, it is reasonable important to have the right wires in the right places ;)
  • Like 3
That is basic QA for any manufacturing business to test, especially if it's hand made and not automated. I would not be happy.
But as already stated, stock dwell times will impart less than a quarter of the energy required for design spark power. You need an ecu that has adjustable dwell. And if you're on a stock ecu you can't be doing anything too exciting power wise so r35 coils are overkill.
Edited by burn4005
  • Like 1
So the companies I have been working with, the supplier and the merchant, are both fantastic groups. They have been helpful the entire time. The custom harness came from the merchant and they are absolutely understanding. The ecu is bring paid for. No hard feelings. It was an honest mistake and we're good there.
The supplier said that the R35 coils are going to work but I will not get the full effect from them without the adjustment, and I understand that.
For now, I only have a stock ecu. Future plans certainly have a need for these as I will be building up this winter. My budget is far more forgiving if I do it a little at a time. ie. the woman isn't as surprised at the cost when it is drawn out over time :)
I went this route simply because the stock coil harness was crumbling and since I was going to upgrade anyway, now is a good time.
It is better this way anyway. I couldn't imagine if this harness ruined a new Haltech!
Thank you for all the help and suggestions!
  • Like 3
Stock dwell time on the ECU will work with R35 coils if you are running a mostly stock engine or somewhere near it. Dwell time increases only come into play when the  spark is getting blown out from excess pressure in the chamber.
Excellent. Thank you.
As I get more into this thing, I'll have the ecu to compliment the rest of the parts.
This is stick for now. Just a 3 inch exhaust and hks filters. Nothing crazy
Well, massive thumbs up to the supplier that they took responsibility and corrected the impact of the issue with no problems.  That is by no means guaranteed in car aftermarket, so good on them.
  • Like 1
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
