  • Replies 56
Awesome looking car.....
Cannot wait to see it out on the street's......
Just checking how much a kidney goes for on the black market, so then i can start looking at something similar!!!!!
  • 2 months later...
Kabab with cheese,
OK What needed to be done.
Brake pads have to be Standard $1000 per pair or borrow some like I did.
Zorst & header pipe has to be standard, I bought a STD one $700 from turbo back. I can hire the STD one out to any R34 GTR owners if they get nicked by the RTA or need it for complicance $50 per week.
Suspension. I had the STD springs and sustension put in the back of the car when I bought it. I now have for sale a 500km old HKS hypre Max II for an R34 $1600.
Wheels and tyres. Need to be STD so I borrowed a set of R34'swheels and borrowed the STD size tyres $150 with all the work.
Air box borrowed the STD airbox.
On top of that the windscreen part numbers did not match up so I had to put a new STD windscreen in $400
The normal compliance stuff like fluids, the complier looked after.
Once it was registered I had some mods done to it, he he! The Zorst, pods and wheels went back on.
Other then the 5 months it took it was easy!!!!!!!!!
Anyway, what are peoples thought on changing my log on or should I simply stay
Oz GTR97V?
    • Tbh, I have no idea who this is bahahaha. hint? I live in the real world now, certainly not swinging spanners anymore though
    • Joey, are you still in playing "spanner club" Mafia somewhere mate? Or you now out in the real world where you actually have to work for a living? BTW, the car looks clean, and the pods look sweet, are you removing to go full OEM type of resto?
    • I like the idea of tagging the model, and if GTS-t/GTt or GTR, and then a what, so wiring, engine, suspension.   That way you end up with a matrix, all content R33 GTST, or you can find all content that is wiring related for example.
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
