  • Replies 175
I'M BACK BABY!
Noumea was nice, but I had to look at bloody peugots and renaults all week.
I did see a brand apsnkers Evo 8 though. Sexy car.
Early next week will be the best time to meaure the front bars.
Maybe people could meet me at my work.......
Welcome back Bass :rofl:
I'll be heading over your way for my Recaro's fitting late next week. So PM me details for your work and I'll drop in to measure it up. I dont think it will be that much different to the nissan sports measurements?
GTTR34
Sorry I couldn't talk much on the phone, I was at a restaurant for my birthday today.
Friday is fine with me.
Anytime.
DAZ, I'll need your measurements too.
HEy Bass I can swing past your work on Friday morning around 10-11am, can you pm me your details?
PM ur work address to me too Pete...
Daz can u pick me up from the Recaro fitting place on Friday bruvva? It's in Mitcham too.. we can go for a cruise or something.
See u tomorrow night anywayz.
Erik.
What front bar do you have?
Could you please take some detailed photographs of your front bar.
From straight on.
From directly above.
From above where the bumper and headlight comes together
I don't know anybody in Melbourne with a C-West front bar.....
Does anybody?
No worries.
Erik's website lists the car as having c-west but he posted Top Secret here so I guess thats what he has now?
How far away are these Pete? I am running out of cash....!
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
    • Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.    I should have said just change from 5th to 4th gear … down shift. There’s a grind.    I have a new clutch X clutch … but as I said all the changes in other gears are fine.
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
