OKAY.
Anybody in Melbourne who really really needs their guides today, please call me.
I have pulled a favour at the subbies and he's cutting the panels for me right now.
Daz and Matt are coming to pick them up this arvo and if anybody needs one, for circuit racing or Auto Salon, please let me know ASAP so I can bend them up this arvo.
0419 101 639
Call me if you need to.
BASS OUT
  • Replies 175
I can wait til next week - no need to bust chops, I am sure my car will survive.
But if its not a hassle I can also pick up this weekend - but its not urgent for me mate :D
Its up to you Pete!
Ok after breaking two ring spanners I managed to get my guide on. Fits very nicely and looks great. Sidchrome tools definitely worth the price as a side note.
Will see what sort of temp improvements I see over the weekend.
Thanks.
NJR
I'm glad you like it. I think they all came up quite well.
Especially since I trial fitted every single guide to my car.
Anyway, take a photo for the guys and post it up.
Also, could you please give me a trader rating. Thanks.
And for those with Standard Bars and AFtermarket bars, here's the story.
The subbie who are cutting the bars were going to do them Friday afternoon, but as Friday's go, they didn't end up doing them.
They will be cut early Monday, and I expect to be able to ship them by Tuesday afternoon.
Sorry to Matt who drove all the way out to collect them.
Let you know Monday when they are going to be ready.
BASS OUT
NISMO BAR PEOPLE
P.S. I will also be playing around with my nismo guide.
You can see on the guides you have that there is a section which ic cut out but unbent.
This is for later modification to force more air into the intake.
I didn't want to mees around with yours as I have a lot of playing to do with mine before I can finish it. Also, there's a good chanch that when I try to bend mine it will kink somewhere and I didn't want to damage yours.
When I do complete the mods, I will take heaps of photos for you all.
BASS OUT
:D
Didn't fit. Well after buggerising around for a bit chopping off two little bits that were stopping the thing fitting on, then accidently cross threading one of the bolts (which stuffed the bracket not the bolt) I went to shut the bonnet and it wouldn't shut. I even tried sitting on it but no go.
It seems my bonnet has some bits on it that yours doesn't Bass. Not sure that I want to pull them off.
Serious?
Can you take some photos of the bit that your bonnet has please?
What little bits were stopping it going on?
I took some photos but haven't had a chance to up load them yet. Will do that tonight when I get home.
It's probably easier if I circle the bits on the photo before I post it tonight.
SHIT. I did't realise that his was a four dorr, but I'm not sure there would be any difference.
Having said that, I do remember a thread about ylwgtr's car and that he had a four door radiator support or something.....
Maybe there is a little difference.
Bugger.
4 door shouldn't be any different from the firewall forward.
http://www.skylinesaustralia.com/forums/at...achmentid=22571
see where you have put the foam stuff... I have these rubber flaps that hang down a little bit.
Ah, right.
Maybe they are factory attempts at the same idea??
If there are flaps there, it forces air to be pushed down underneath the radiator support.....
I guess.
does the nissan FAST software show car components... if it does,, it might show all the rubber under the bonnet,,
i don't have any rubber flaps!! and mine is a series II ,, talk about cost cutting bye nissan.. can someone post pics of their bonnet,, i might go to nissan and get some rubber flaps for the bonnet,, just need to know how many there are meant to be, and location,,
atleast i have the bonnet lining,, sheesh!!
afro
Ok here is two pictures. The red circles are where I had to modify. The middle one is because once the guide was on I couldn't get a finger under the latch to open it. The one on the right is not the same as the bit on the far left as it should have been but that's no big deal, I just cut it off with a hacksaw.
The pic of the bonnet is self explanatory really. The rubber flaps are held on with a bit of metal and so when you add the bit of rubber attached to the bonnet to the metal holding it on to the rubber that normally hangs down but can't because of the air guide it's all about 2cm thick.
Guest
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
