Hi guys.
I’m sorry to those who have those flaps of rubber that come off the bonnet.
This is the exact reason that you are having trouble making the guides fit.
I do not have those on my car, and it looks like they never have been there.
They are in the same place that I put the foam to stop the bonnet rubbing on the panel.
If you remove the rubber flaps, they should fit without a problem.
Again, I’m sorry but it looks like you will need to remove the rubber flaps to make the guide fit.
BASS OUT
  • Replies 175
Okay guys.
Good news. I just picked up the guide blanks from my subbie.
They are getting bent as we speak.
I will bring the appropriate amount to the Meeting tonight if anyone wants to pick them up then.
Other people, I will send them off tomorrow arvo.
Cheers
BASS OUT
GroundRun.
I'll be at the Skyline Club meeting at the pub in Hawthorn tonight from 8pm onwards, otherwise you can give me a call and pick it up between 5:30 and 7:30 from my work.
Call me, 0419 101 639
y.
Interstate people.... Your guides are all boxed up and awaiting the truck.
Afro, Erik and Coxy, you should see your guides in day or two.
Coxy, please sort out the payment, you have all the details.
Melbourne people, NismoR34, GroundRun and CNBLOW let me know when you can come and pick them up.
I'm in Mitcham or Doncaster.......
Come and git em.
BASS OUT
PS. Don't forget my trader rating and VOTE FOR MY CAR ON AUSSIEWHEELS!
NismoR34, CNBLOW
I'll be at home all this weekend, apart from the obligatory grandfinal BBQ at my sisters house.
I will bring the guides home with me, so if you give me a call, we can meet up.
0419 101 639
Tonight is good, and Sunday is also good.
Just give me a bell, and we'll organise something.
CHEERS
BASS OUT
Ground Run???
When you gonna call??
I'm bringing the guides home with me this weekend so give me a bell.
Also, could the people with standard bars take a couple of photos please??
Just want to have them on record so I know that they were right.
Cheers
BASS OUT.
ALSO< check out the new project.... AFM to Turbo Ducts.
Well done... now go and clean your engine bay, it's filthy... shame on you!
I fitted mine on too... I left you feedback Peter :( I'll take some pics later today.
:D
:D
:Oops: I working on that now!!!! hehe itll be clean soon
Thanks Matt.
I'm glad the bars all fit very well.
Like I said Matt, "Trust me, If I'm making it, it will be right."
BASS OUT
Well there was some sunshine this afternoon so I went out and took some nice shots of my car.. here's a shot of my shiny new air guide:
In the words of the Irish guys in the Guinness TV commercial, Brilliant~! :D
i have to modify mine alot (c-west front bar),
i started modifying the front bar,, but than decided to hack up the guide,,
so didn't do to much damage to the bar, will show in pics later,,
i'll have to remove the whole front lip of the guide, coz my front grill/mesh wont fit, the front lip of the guide sticks out too far,, once again will post pics later on,,
will update the changes soon,,,
thanks
Afro
Hey Bass..thanks for the guide...i went to put it on but it wouldnt fit past the bonnet unhook latch...i noticed on the guide a marking where it was hitting where i assume it was supposed to be cut but wasnt cut...after follwing the line with a hacksaw blade, i cut out a little section and then it was spot on...dont know if anyone else had the same problem with the standard bar...nevermind it fts now and looks good....
thanks.......oh and i hope u sorted out the cabbie :P
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
