Hi all.
Bought my stag about a year ago. Had 87000kms on it. I was skeptical of whether the k's are genuine but found no evidence to suggest it wasn't before I bought it and even up until now. I'm first Australian owner and I'm in love with the car. This is my second car, and the first car I've ever modded and worked on beyond minor servicing. So far I've put in BC coilovers, HKS intake, alpine head unit, done the 2 stage boost solenoid earth mod and put in a 225lph walbro pump.
I love this car a lot and I'm still just as stoked with it now as I am when I bought it.
Cheers for all the info SAU has provided while I've been lurking, and thanks for any welcomes and help you all give in the future!
Cheers,
MG
  • Like 2
https://www.sau.com.au/forums/topic/477615-hi-all-intro-to-my-stag/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
