Hi all,
I've been told I should intro myself in the wagoneers section, so here I am :)
Bought my series 2 rs4 about a year ago with 87000kms on the clock, I was skeptical about whether that was genuine but I've found nothing to contradict it so far! I am the first Australian owner as well.
Since buying I've changed the wheels, chucked in some BC coilovers, put in an alpine head unit, put in a hks intake, and done the boost solenoid ground mod to get around the 2 stage boost system. I've just had a 225lph walbro fuel pump put in but am currently having issues getting the direct wire mod to work for me.
I'm extremely stoked with the car considering this is my second car and the first one I've modded and worked on beyond minor servicing.
Thanks for the wealth of info you guys have accumulated on this forum, it's been real handy.
Cheers,
MG
  • Like 1
https://www.sau.com.au/forums/topic/477616-intro-to-my-c34-stag/
On 7/2/2019 at 6:47 PM, Majorgrief said:
Hi all,
Cheers,
MG
From this angle looks very similar to my S1. You have the advantage of being able to easily slot in a Nistune chip so with that and a manual (for now) boost tap you could add a little extra zip...
Ahh they do look similar. I gotta get me a clear indicator and black weather shield above the windows. Looks good. Extra boost is definitely on the agenda and I'll have to look into this nistune chip too! First gotta clear up a misfire that I'm getting and get the timing belt done :( no fun mods for a minute :(
  • 3 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
