21 hours ago, Slap said:
They are basically asking everyone "what car is better" ? Very American to ask that, and all that does is instigate the stupid posts on the you tube comments section. Why do we need to compare them as the 32 and 34 in the video are completely different, and have very different build concepts. Both are very good in different ways, but not really directly comparable.
Well done to Dahtone on the electronic throttles, but I still have to ask, "why" ? Just to be different ?
  • Like 1
DBW allows for idle control without the AAC valve, cruise control without a lot of extra plumbing, traction control, etc. You can also control transients a little better in theory.
I personally don't trust aftermarket ECUs to have good DBW code though, failsafes become much more important with DBW, if the throttle can fail open that's a big problem.
Edited by joshuaho96
