I bought a 1991 4dr non turbo rwd with a bad tranny. I have installed a replacement transmission but am now having trouble getting overdrive 4th to work and it also feels like it is starting off in second (really slow!). I have tested sensors and solenoids and all test good. The tcm is my question. I can’t get the power light in the dash to come on to test it. Won’t come in when you turn the key or when pressing the button. I can’t find and pinout or wiring schematic anywhere for it. It is a 48 pin plug. Ecu has no codes.either. I did get the power button light to come on with the last transmission but it was intermittent.
Edited by Grewell2
The R32 GTR manual has everything you need. Yes, including the TCU wiring for non-GTR autos. Because it also covers GTS4s, including autos. The AWD and RWD turbo and NA autos are all similar enough wrt the power button and TCU interface.
You should consider getting it to a mechanic who has a good diagnostic scanner and find out what codes the TCU might be suffering with.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
