Hi all,
Currently in the middle of replacing the timing chain on my VQ25DD (2002 M35 Stagea).
While I've got the engine at TDC, and the crankshaft mark and intake cam sprocket marks lined up with the old chain markers. I've found that the top stretch of old chain between intake cam sprockets was too spread apart, so that the new chain can't reach the last tooth to make the new chain marks align with the sprockets.
Hopefully the photos make it clear what I mean. Comparing that section of the old and new chains you can see the difference in length of about half a chain link. The two photos of the cam sprockets show one mark lined up, and the other as best I can make it reach - one tooth too short for the sprocket mark.
The best thing I can think to do is stow the tensioner on one or each of the cam chains and that might give me enough play to nudge the chain over that last tooth.
Any better ideas or if this is ok to do, or even work as I'm hoping?
hoping @scotty nm35 might be able to weigh in...
Also looking for recommendation on the silicone/rtv product to use to reseal the case on when the time comes.
cheers!
This might be a silly question (as I don't know these motors at all), but in your chain side-by-side photo, you have 2 pink marks on the top (new?) chain lined up with 2 orange marks on the other chain. I can see the 3rd mark on the top chain is orange.
So whilst all 3 marks on the bottom chain are orange, is there any possibility that you're lining up the wrong marks there?
With the silly question out of the way - I note that the cam gears have slotted holes. Would these be to provide you with the 1/2 a tooth's worth of adjustment to account for chain stretch?
No such thing as a silly question.
Photo colour may be misleading, the old chain is two pink for cams, one orange for crank. The new chain is the same but old chain has slight colour fade.
As it happens, I’ve resolved the issue by slightly rotating the cams as required using the hexagonal ring. This is actually mentioned in the manual I just found for the 2003 G35 coupe. Just have to be very careful you’re not turning the cams to break a valve.
I also realised each intake and exhaust cam sprocket marks align with subtle bumps formed on the inside of the rear chain case at TDC. This let me determine that the LHS cams were slightly off mark while the RHS were on mark. Made it easy to choose which one to turn to fit the chain and also have some confidence you’re within reasonable margin of safety as you move the cams a degree or two.
  • 1 month later...
  • 1 month later...
@scotty nm35hey mate completely of topic - I’m trying Message you on sau but can’t get a hold of you re: injector wiring for c34 rb25det - can you pm me so I can’t get in contact
  • 4 months later...
2 hours ago, Riccardo said:
Can anyone help where too buy one of these timing chain kits for the Vq25dd stagea. Can only find on ebay. Can you only get them from Nissan?
No you can also get them from Ebay. Have you tried messaging Nicko or Hutchwilco?
  • 1 month later...
You can buy those kits in your local Nissan dealer but you will have to wait roughly for about 6 weeks to get all spares parts delivered from Japan, dont think any dealer across the country would have those kits stock up.
Anyway I've purchased my parts in Dubai long time ago and a wallet damage was around $2000 for a full cart of extra parts you would also need if you pop her cherry for a full replacement of any worn/defected internal parts.
How's it going?
Just came across this: they also sell the parts
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
