Hi SAU,
As the title states, i'm wanting to go back to stock cams on my R33 GT-R as the cams that are in the car at the moment are totally mismatched, plus i'm looking for more of a responsive setup. The cams in there at moment are HKS Step 2: INT=264 duration 10.2mm lift, EXH=272 duration 10.0mm lift. The cylinder head has been CNC ported.
Don't know to much about machining.
My question is: Will stock cams fit in this cylinder head? The HKS cams are rather big compared to stock (INT=240, EXH=236). I wasn't the one who built or commissioned the build of this engine so I wouldn't have a clue how much head work has been done.
I'm aware that clearance work is done to fit some cams. Would replacing a larger cam with a smaller cam be possible? Or has there been to much 'cylinder head material' removed, making a smaller cam loose/not fit? (my lack of mechanical knowledge is showing lol)
Any and all help appreciated.
https://www.sau.com.au/forums/topic/477767-going-back-to-stock-cams-rb26/
OP,
I see your other thread asking to buy stock cams.
If you don't have any stock cams and therefore have to pay for them.....why would you do so? Just buy some nice Camtech or other decent Aussie cams that a bit milder than what you have? There are great options available that will be really responsive, and 10x better than the stockers. Not least because you will be surrendering a LOT of lift going back to the baby stockers.
Appreciate the replies guys. Learnt a bit from your responses.
As for cam selection, im just going by what my mechanic/tuner (Racepace) is suggesting. Ill have a look at what other mild cam choices there are, however at $100-$200 a pair, stockies arent going to break the bank.
As for advancing timing, thatsl was pretty much already taken care off during tuning.
Thanks
Yuh, but that's just the purchase price of the cams. On top of which you have to throw money at the workshop to open the engine up and swap them and do the clearances (and probably some tuning). Once all that is on top, the extra money for a proper cam is not actually that big an increment.
Yes that's true. Head is lifting due to dodgy tune from previous owner's tuner. My mechanics certain it's just a head gasket (fingers crossed its's just that) so engine out, recondition, new gaskets, tuning etc. Thought this would be opportune time to get cams changed while heads of and dismantled.
For a 2.8L, with hks 2530s, running e85, what cams should I have? (street driven so response is priority)
Poncam type B's are another recommendation for $1K and Camtechs lowest duration set are priced the same. My only hesitation is; will my gains from buying a new set of aftermarket cams for $1000 be even worth it?
I want to go with my tuners advice as they are pretty much  the go to guys here in Melbourne for RBs/GT-Rs, but I'll definitely be asking him if there is worthy benefits to the cams mentioned above.
Will also be going through dyno results forums.
A ported head will really really benefit from the extra lift. You'll be stifling it and giving away a LOT of power. I'd do it (buy cams), and I'm allergic to spending money.
Camtech.....I'm a bit WTF!? at the moment. I just went to look at their site and they don't show RB26 cams. What am I missing?
If I was to use their RB25 Neo cams offerings as a guide, I'd suggest...actually nothing. I'd want a 10mm lift at least, on the 264s°.
Unigroup do an 11mm lift on 260°. They have others (less lift, but I'm not sure exactly what's on offer) too. I'd be thinking that if your head is all coming off and apart, then whatever is needed done to fit those (in case any more clearancing is required) would be worth it.
Kelfords (Christchurch) have a couple of options. This https://www.kelfordcams.com/nz/camshafts/nissan/rb26dett/182-b-camshaft-set.html is 260° & 10mm. They will also custom up a cam. So if you wanted something with 10.5 mm of lift (they have some, but with more duration than you seem to want), they could be persuaded to cook something up.
  • Like 2
For camtech https://camtechcams.com.au/camshaft-search?c_association[1]=14&c_association[2]=56&c_association[3]=126&c_association[4]=127
Will be doing some cam research in regards to everything we've talked about, before the big day.
Thanks GTSBoy
  • 2 years later...
Thanks GTSBoy
Hey there, did you ever get your head sorted out. I have a similar issue, where I have an overbuilt CNC ported head with oversized valves, but am switching to 2530 ish size turbos. I have 260 10.2 procams that I can use, I’m just kind of worried about that the big power work on the head will affect low end power. The bright side was I hoping to make power at lower boost.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
