Gday! Single dad from Vic. I joined bcoz id like to 25/30 my gq. I havea 25 sitting here, have a gt3576 aswell.
Im concerned that i just cant afford the mod, when u start talking trigger kits, vct mod, clutches, building turbo block, building a turbo mani, etc
Any insight would be great, ta ??
https://www.sau.com.au/forums/topic/477781-gday/
10 hours ago, Axed29 said:
Yeah, could just chip away at the build..
Ill build it myself, im just wondering if 25/30 is worth the $$ i geuss
worth it is pretty subjective. different people have different expectations and budgets etc. so it is basically impossible to answer your question.
Having said that i would say an LS swap would make heaps more sense into a Patrol.
https://www.sau.com.au/forums/topic/477781-gday/#findComment-7910948
I'd say that any RB build into a Patrol is a horrible waste. Big lumpy tank needs a big lumpy motor. LS is smart option for defs. If you must have Nissan, start at VH41 or 45 and work your way up from there. 41 with a turbo on 8-10 psi will be enormously torquey.
See Skid Factory for turbo diesel shenanigans in Patrol. See MCM for turbo VH41 in Stagea.
https://www.sau.com.au/forums/topic/477781-gday/#findComment-7910964
People have built RB30sfor very little money - just rings and bearings. The trigger kits etc are not essential but you are still talking quite a few thousands and I have no idea what it would take to put it into a patrol.
With about 2.5 tonnes to shift it would take a massive power boost to make it goes fast and then I would think it would be pretty scary to keep on the road.
Do some searching - someone has done this before - don't know how this worked out.
https://www.sau.com.au/forums/topic/477781-gday/#findComment-7910997
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
