Looking for some examples of people with aftermarket cams and new lifters.
Genuine lifters are drug money and there are some aftermarket options. But unsure if they will do the job as well as genuine.
Cams are 268 camtech.
Not looking at solid conversion as the rest of the valve train is sorted.
https://www.sau.com.au/forums/topic/477786-rb25-hydraulic-lifter-replacement/
Tell builder to use old ones unless noticeably worn. It's not a huge job if you have to replace lifters due to ticking. Not the same as not replacing rod bearings that requires a tear down to re address later.
Or plug them ?
4 hours ago, Ben C34 said:
Or plug them ?
1 hour ago, WR33KD said:
You can plug hydro ones to make them solid, this makes your redline go above 7500
1 hour ago, Ben C34 said:
Where do you shim them in that case? And how are they plugged?
Seems related to shimming VLSDs. Same level of mechanical respekt. Fo shizzle.
My hole head got sent down the line to get built when I built my motor, if I remember right it’s in Christchurch. Was either that or change the head
not sure what "down the line" means. My question was regarding how are the valve clearances set when you make a hydraulic lifter solid? i havent seen it done, (aside from for dummy assembling purposes, checking piston to valve clearance, definitely not a running motor.)
If the lifters had no problems before and you have kept the oil well serviced then there’s no good reason to be rid of them now. I’m sure you can buy aftermarket lifters somewhere but it would likely be a gamble on the metallurgy and tolerances in them.
Purchased the engine second hand.
Sighted running, but since I didn't know the history I've rebuilt it.
Hence my own apprehension to reuse too.
Down the line means down the other end of the country. Hence Christchurch is down the line of where I live.
Not sure how it’s done as it wasn’t me, the head alone is cost me just over 5k for the work done to it.
Was either that or a neo head
