Hey everyone,
Need a new clutch for more power / current one is worn, I have the GTT (RB25DET Neo) was wondering if anyone has any tips on what to look for?
Will any aftermarket single plate do? Currently looking at https://www.gameonmotorsports.com.au/npc-nissan-skyline-r33-gtr-pull-type-clutch-r34-gt~44571
Looking to make about 375kw~
Edited by thenixtone
https://www.sau.com.au/forums/topic/477812-suggestions-on-a-new-clutch/
10 minutes ago, thenixtone said:
Ah right, my bad, I thought this was a forum.. for discussions. A clutch place isn't going to tell me if their clutch is shit, are they?
Maybe they would if you asked about an unsuitable model in a particular application.
call npc. Tell them what you want. Call Jim Berry. Call acs
On that basis, we could trot out the passive aggressive claim that no-one has ever asked that question on this forum before and that it would be impossible to search for previous/recent discussion.
You mean like the original passive aggressive comment I was responding to?
And of course I searched. Its hard to find information with exact power figures. How do you think I came across the NPC clutch that people on here recommend..?
Every thread that COULD be answered elsewhere is useless apparently.
Besides 'this one fits' I was after actual experiences and feedback.
Budget? Where/how you are using the car?
I have ACT 6 Puck with Extreme pressure plate (rated to 830nm iirc) on my rb30/25 street car (550hp/730nm) and Im happy with it. We dont really have bad traffic here where I live though
On ‎18‎/‎07‎/‎2019 at 4:46 PM, WR33KD said:
OS R3C here aswell, only clutch you will ever need
In a rwd application under 400kw yes, so fine for the GTT in this application, but not in a GTR launching at 7000rpm +. I killed a brand new one in one drag weekend, completely warping the metallic floating discs to the point the clutch wouldn't disengage.
Probably not relevant in this situation, but just pointing out that they are not the "be all to end all" of clutches at all. They also drive like shit on the street, very hair trigger engagement.
  • Like 1
2 minutes ago, WR33KD said:
Mines mint she feels like a standard clutch, done plenty of hard take offs and still feels great. I’m over 400kw and rwd and it’s the bees knees and it has a changeable centre not like others
What you got?
Jesus..
Is the difference between button and cushion button that big of a deal for street driving?
29 minutes ago, thenixtone said:
What you got?
Jesus..
Nope. The cushion has very little effect. A button clutch is going to be pretty much off or on and  don't like slipping
All multiplate clutches have a changeable centre hub by design, so thats not anything special. Maybe your R3C seems a bit nicer to drive in a rwd car, because any metallic triple plate I've had in a GTR has a hair trigger and not really slippable, definitely nowhere near a standard or full face clutch plate type. I've had ORC (Ogura), Xtreme (ACS), Exedy and OS Giken all in triples and all basically felt like the same clutch.
OP, The Nismo twin, NPC twin or even the OS giken TS2B will probably be a nicer clutch to drive for you and handle your power for quite sometime. $1500 or less though is going to limit you to buying a single plate though, as I think you'll need to stretch a bit more to at least go a twin or triple if you can afford it.
Awesome, thanks for the info. Think I'm going to spend the money and get the coppermix.
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
