Hey everyone,
Need a new clutch for more power / current one is worn, I have the GTT (RB25DET Neo) was wondering if anyone has any tips on what to look for?
Will any aftermarket single plate do? Currently looking at https://www.gameonmotorsports.com.au/npc-nissan-skyline-r33-gtr-pull-type-clutch-r34-gt~44571
Looking to make about 375kw~
Edited by thenixtone
https://www.sau.com.au/forums/topic/477812-suggestions-on-a-new-clutch/
10 minutes ago, thenixtone said:
Ah right, my bad, I thought this was a forum.. for discussions. A clutch place isn't going to tell me if their clutch is shit, are they?
Maybe they would if you asked about an unsuitable model in a particular application.
call npc. Tell them what you want. Call Jim Berry. Call acs
On that basis, we could trot out the passive aggressive claim that no-one has ever asked that question on this forum before and that it would be impossible to search for previous/recent discussion.
You mean like the original passive aggressive comment I was responding to?
And of course I searched. Its hard to find information with exact power figures. How do you think I came across the NPC clutch that people on here recommend..?
Every thread that COULD be answered elsewhere is useless apparently.
Besides 'this one fits' I was after actual experiences and feedback.
Budget? Where/how you are using the car?
I have ACT 6 Puck with Extreme pressure plate (rated to 830nm iirc) on my rb30/25 street car (550hp/730nm) and Im happy with it. We dont really have bad traffic here where I live though
On ‎18‎/‎07‎/‎2019 at 4:46 PM, WR33KD said:
OS R3C here aswell, only clutch you will ever need
In a rwd application under 400kw yes, so fine for the GTT in this application, but not in a GTR launching at 7000rpm +. I killed a brand new one in one drag weekend, completely warping the metallic floating discs to the point the clutch wouldn't disengage.
Probably not relevant in this situation, but just pointing out that they are not the "be all to end all" of clutches at all. They also drive like shit on the street, very hair trigger engagement.
  • Like 1
2 minutes ago, WR33KD said:
Mines mint she feels like a standard clutch, done plenty of hard take offs and still feels great. I’m over 400kw and rwd and it’s the bees knees and it has a changeable centre not like others
What you got?
Jesus..
Is the difference between button and cushion button that big of a deal for street driving?
29 minutes ago, thenixtone said:
What you got?
Jesus..
Nope. The cushion has very little effect. A button clutch is going to be pretty much off or on and  don't like slipping
All multiplate clutches have a changeable centre hub by design, so thats not anything special. Maybe your R3C seems a bit nicer to drive in a rwd car, because any metallic triple plate I've had in a GTR has a hair trigger and not really slippable, definitely nowhere near a standard or full face clutch plate type. I've had ORC (Ogura), Xtreme (ACS), Exedy and OS Giken all in triples and all basically felt like the same clutch.
OP, The Nismo twin, NPC twin or even the OS giken TS2B will probably be a nicer clutch to drive for you and handle your power for quite sometime. $1500 or less though is going to limit you to buying a single plate though, as I think you'll need to stretch a bit more to at least go a twin or triple if you can afford it.
Awesome, thanks for the info. Think I'm going to spend the money and get the coppermix.
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
