Depends what you mean by very quiet?you’ll never make it sound stock but getting something that is very streetable without drone is definitely possible.
A lot of people are using AES mufflers now and the results have been great, I’ve got a set for my car (getting done next week) and I heard Andrew Hawkins car on the weekend and am confident in my choice
https://www.sau.com.au/forums/topic/477821-4-inch-exhaust/#findComment-7911133
9 minutes ago, r34unit said:
sorry is there another thread ?
Nah, offline - but they have had good results making 4" exhaust flow well without being too loud so hopefully one of them will weigh in
Edited by Lithium
https://www.sau.com.au/forums/topic/477821-4-inch-exhaust/#findComment-7911134
For those building their own exhaust systems at home, what is the best way you've found to make accurate cuts on larger diameter stainless?
I've started building a 4" system, using a cold saw (dry type) and it's been a pain in the ass.
https://www.sau.com.au/forums/topic/477821-4-inch-exhaust/#findComment-7911237
@JustinP I just used an angle grinder for mine then finished it on the belt sander to get a perfect mating face. I used a 125mm angle grinder with the thinnest blade I could find. Cuts through it super fast.
https://www.sau.com.au/forums/topic/477821-4-inch-exhaust/#findComment-7911338
12 hours ago, hattori hanzo said:
can reaper send you an exhaust or do they need the car in the workshop?
He supplies mufflers to order mate. Measure up what suits you and check out his gear and order up the style you like ?
https://www.sau.com.au/forums/topic/477821-4-inch-exhaust/#findComment-7911996
  • 3 weeks later...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
