Would need pics of exactly where it is starting to slide out.  Normally if the wiper blades are in the right way up there is a little catch at the end of the blade that holds into the wiper arm
Use a dob of silastic, slide the metal inserts out a bit and work the silastic in as you go, then push the inserts back in.  Will fix it no probs.  Done right you will barely notice the fix.
  On 20/07/2019 at 7:02 AM, sonic99 said:
Thanks guys. Here are photos of the inner and outer parts.
Just bend the tabs out or stick a cable tie around the end or something to stop it moving... they're simply sliding out.
  On 22/07/2019 at 12:30 AM, niZmO_Man said:
Bosch AeroTwin or whatever the new models are called.
Measure how long your blades are, then look up part numbers BBA450 for 450mm/45cm. Double check they are J-hook.
About $20 AUD each, lasts years.
Expand
Thank you Kindly. So just to confirm, I need new blades, not just the inserts. Correct?
Expand
Yes
Quick Bing brought this: http://www.r33gt-r.com/2013/02/another-modern-upgrade-wiper-blades.html
Not hard. Literally lift wiper arm, unhook old wiper, install new wiper.
