FOR SALE:
Nismo 1.3 Bar Radiator Cap
Product Number: 21430-RS012
Description: The NISMO Racing Radiator Cap maintains higher internal pressure in the cooling system than the standard cap (valve opening pressure : 0.9kg/cm2 *1.2kg/cm2 for Z32). It prevents the coolant from easily boiling and vaporising (the boiling point is approximately 6℃ higher than the standard cap’s 0.9kg/cm2 threshold) and improves cooling efficiency. The NISMO Racing Radiator Cap can also be used on vehicles with a small radiator cap (external diameter 45).
Product Warning
  • Because the NISMO Racing Radiator Cap maintains high pressure in the cooling system, be sure to inspect the radiator and hoses before installing the cap to be certain that they are not damaged and that there are no leaks. Cars are particularly prone to problems due to wear. Even if your radiator and hoses appear to be working fine at low pressure, flaws may appear at higher pressure.
  • Cap can be used on vehicles with a small radiator cap (external diameter φ45).
Price: $54.95 ($15 Shipping)
Buy online: https://www.vspecperformance.com.au/nismo-racing-radiator-cap
Buy in-person: Visit us in person 17-19 Terra Cotta Drive, Blackburn, VIC 3130 - Accepting Cash, Mastercard or Visa.
1.JPG.425729ea1541161cd26242d720efc107.JPG2.JPG.341bbe64fd6057ef989f4ffd32bb5f88.JPG3.JPG.489419130502a513c92e67b08b731582.JPG
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
