Good morning all,
yesterday i went to get my car tuned by one of the only shops in Canberra that do Nistune and was unsuccessful. They were unable to get the AFRs to quickly drop to a safe level while boost was beginning to build without making the fuel map overall too rich. IE the map was either far too rich IE 10:1 or AFR whilst boost was building/peaked at 10psi was still 13-14:1.  The shop questioned the authenticity of my AFM which i know being a z32 they're have been a lot of fakes. However I bought mine new through EFI solutions (AKA TAARKS) along with my injectors which have the counterfeit code and holographic seal etc (injecotrs that is AFM didnt). I have bought many parts from them including genuine nissan, and think they are a genuine dealer, and am hesistant to go buy another one.
The tuning shop did admit it had been a while 6months since they had done a Nistune and i don't tune as many of these older basic setups like mine. I am at a bit of a loss at what to do as i dont really want to throw more money at it without knowing the problem, and would rather take my car to a tuner who is more familiar with my setup (will describe below)/ Skyline who can help diagnose and tune.
My current setup is as follows:
R32 Nistune ECU with latest feature pack
EFI solutions Top fuel rail kit, runnig stock FPR with Bosch 0 280 157 187 495cc Injectors (off the shelf GM LSA injectors)
Bosch Z32 AFM from EFIsoltuions, new in Blue Box (pic below)
Hypergear G2 21U Highflow
Greddy Profec OLED EBC
Custom Hard intake pipe joining to stock Airbox, Return Bov
GTR BOV
NPC clutch
SPlitfire coilpacks
Standard Walbro 255 with the wiring mod.
NZ EFI AFM adapter harnes
Car setup history
I did purchased the nistune software and cable to get running, although Matt from Nistune did set it up for my injectors and AFM. Had to increase the Kvalue by roughly 60% to get stoich AFRs at idle and light cruise. Car runs  pretty well off boost but richens to at least 10:1 (minimum of my PLX wideband) when making positive pressure.
I have also conducted leak test prior to tune.
This morning check fuel pressure was 3bar at idle wit no vac line approx 39spi with vacc line.
Looking for advice on what to next and tuners close to Canberra who being familiar with this setup can diagnose and tune without throwing a huge amount of money at it.
Cheers
One thought was  maybe it could be the AFM adapter as i  did notice some people wiring pin c of the z32 afm to chassis. However probing the Z32 AFM pins C and D(signal ground) are linked so connecting pin c to chassis would essentially put the "signal ground" to chassis which sounds wrong.
Not saying you got it wrong but just posting up some info from PaulR33
Plus you may have a fake MAF - should have Nissan in the box (actually read the whole thread to get a better picture).
http://forum.nistune.com/viewtopic.php?t=1431
(attached)
Installing Z32 AFM.doc
(attached)
Hey there, thanks for your response and taking the time to read. I did think that too and have looked at a few counterfeit threads including nistunes one.
Bosch have produced a newer z32 afm with no logo in the box, which was updated in Nistunes Afm counterfeit PDF.
I did also think to check with Paul's wiring diagram and that some z32 wiring plugs have 4 pins and hence to link wires c&d.  However pins c&d are linked together on the z32 afm itself so essentially the same thing
So on the weekend Matt from Nistune sent me a base map set with 495cc injectors and a Rb25AFM.
Uploaded it and attached my stock RB25AFM and same thing, had to increase Kconst by around 55-60% to get it to run, could also do the same with TIM(Total injection Multiplier)
Also did another pressure test with a more accurate gauge. 39PSI with Vacc line same as before 48PSI no Vacc(made a mistake in first gauge reading was increments of 2 not 1 so first gauge reading no vac was 46PSI).
Slightly higher reading are not suprising, considering I'm running the wire mod to a walbro 255.
Also applied 18psi to FPR and Fuel pressure gauge went up to 67PSI so pretty linear.
Also swapped in another z32 afm this one a Genuine Nissan and needed less that 5% adjustment in Kconst between that and my Bosch.
Did a few log runs and between genuine nissan z32AFM and Bosch z32AFM and nothing stood out (from my very limited experience/knowledge).
Maybe the Nissan z32AFM, AFRs drop a bit faster when creating positive pressure compared too the Bosch but would have to do some more runs of tighter controls. Was thinking that maybe a scaling issue too.
Welcome to trying educated ideas, or sending logs or maps too anyone who would be willing to help.
Basically want to diagnose if there is a problem or if it was a tuner issue before spending $150-$200 a hour, get halfway through a tune to realise it won't work.
Cheers
The only thing that occurs to me is that your injectors seem unfashionably small. People today would go for more like 1200 or 1600s especially if considering E85.
What duty cycles are you reaching (and for that matter what is your power goal)?
Yes i know :) was wanting to stay as close to my old tune in terms of response and daily drive enjoyment (200rwkw with SAFC). New setup should make 230-250kW.
Max injector cycle 57%. I've attached pics of AFR down peak. Boost response is close to stock turbo. Making boost threshold (currently 10psi) roughly 3000rpm in 4th.
  • 4 weeks later...
Hey all,
Got the car tuned by DVS JEZ, no issues with fundamental setup compared to previous attempt.
Was hesitant to upgrade prior in case there was actually an issue but will now be looking at a new inter cooler and maybe a better cat as Jez couldn't get more out of it "too prone to detonation", note the 230kw run was abandoned.
Have you looked for any boost leaks ?  I know this might sound stupid but I have seen massive boost leaks cause issues just like this one.
I'll definitely do another one before trying again. Spent a lot of time doing a pretty comprehensive boost leak test before. Pumped up to 20psi took 20seconds to drop to 15.
Might be the limit of the turbo, turns out the result which netted 250 by Dr Drift had an ext gate, exh cam gear and maybe a ported manifold
The Nistune ECU assumes a constant fuel pressure, you need to duty cycle the pump at lower RPM/load if you don't want to run rich there. You might be able to tune around that problem but generally speaking you want to avoid confounding variables in your fuel tables as much as possible.
If your fuel reg is working correctly and your fuel pressure is correct based on your manifold pressure, i.e. the tip pressure is constant then there's no reason to reduce the fuel pump's flow capacity.
Stock Skylines do not run a deadhead fuel system, they're all pressure/vacuum referenced.
If you know what you're doing in Nistune you can get the car to idle at stoich.
  • 3 weeks later...
For those interested with return flows, attached are the results for pressure drop, test points turbo outlet and intake manifold. This was done on the road not a dyno so the results vary a bit but can see the drop increase above 5000rpm
Edited by Pattey21
  • Like 1
Love the data man, proves return flows are shit (like I've been saying for ages).
But people will say " mah fully sick car made xyz kWs blah blah blah, it works"
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
