I'm trying to install a new head unit into my 92 GTST, I got the until in but I'm not getting anything from the speakers, I'm pretty sure I have it hooked up right but I read somewhere that the amp in the boot wont operate with a new head unit. I'm trying to avoid rewiring all of the speakers but I'm pretty new to the audio world and any help would be much appreciated.
https://www.sau.com.au/forums/topic/477938-head-unit-install/
Sorry to hear you're having troubles.
We're probably going to need more to go on than what you have here. A couple of pics and a hand drwwn diagram would be awesome and also the make and model of your amp and head unit.
Are you getting power to both the amp and head unit right now? And if so what voltages do you see?
I have power at the head, unsure about the amp I will check it when I get home from my little trip. I have 12 volts and a 5v reference at the head. This is the reference I used to write the head unit. It's a lower model kenwood head unit. Not sure of the particular model right now. I ran into this issue then had to leave for a small work trip.
Edited by Digdug154
  • Like 1
35 minutes ago, GTSBoy said:
There are wires that run from the console back to the amp. These can be made to connect to speakers instead.
But FWIW, just get the seats out of the car and put some new speaker cable in.
The stock working doesnt look too good I agree, but I'd  rather do that during winter when I dont want to drive this car. Right now I just want some tunes while I'm cruising this season
It's possible the car has the "active speakers" still in the car? Then an aftermarket headunit wouldnt work with the system, since both front speakers and the rear speakers are controlled by individual amps.
The front speakers were an easy replacement, the rear amp can be bypassed pretty easily as well
Edited by Hcr32typem
Yes it does have active speakers! How do I bypass those amps properly?
The front speakers should be pretty straight forward the rear takes some cutting and splicing. I'm trying to find the guide I used to bypass the rear amp that runs both rear speakers.
Found the guide I used.
I used crimable caps to seal the wires together, left the rest of the plug intact so that I wouldnt have any potential crossed wires. Works fantastically.
I'm running 4x6 in the front and 9" in the back. They're just cheap Dual speakers (cheap American brand) but they sound fantastic compared to the originals whose membrane had disintegrated like 10 years ago haha
4 hours ago, Hcr32typem said:
saudering iron
Now, it's one thing for you Yanks to say "soddering iron" (when it is spelt soldering, and said with the L pronounced like in the word "older", by the original architects of the language, and us Aussies), but it is another thing entirely to spell it the way you weirdos say it! Did you make up the spelling "sauder", or is that actually how some/all of you write it also? If so, where the hell did it come from?
  • Like 1
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
