I'm trying to install a new head unit into my 92 GTST, I got the until in but I'm not getting anything from the speakers, I'm pretty sure I have it hooked up right but I read somewhere that the amp in the boot wont operate with a new head unit. I'm trying to avoid rewiring all of the speakers but I'm pretty new to the audio world and any help would be much appreciated.
https://www.sau.com.au/forums/topic/477938-head-unit-install/
Sorry to hear you're having troubles.
We're probably going to need more to go on than what you have here. A couple of pics and a hand drwwn diagram would be awesome and also the make and model of your amp and head unit.
Are you getting power to both the amp and head unit right now? And if so what voltages do you see?
Expand
I have power at the head, unsure about the amp I will check it when I get home from my little trip. I have 12 volts and a 5v reference at the head. This is the reference I used to write the head unit. It's a lower model kenwood head unit. Not sure of the particular model right now. I ran into this issue then had to leave for a small work trip.
Edited by Digdug154
  • Like 1
  On 26/07/2019 at 1:16 PM, GTSBoy said:
There are wires that run from the console back to the amp. These can be made to connect to speakers instead.
But FWIW, just get the seats out of the car and put some new speaker cable in.
Expand
The stock working doesnt look too good I agree, but I'd  rather do that during winter when I dont want to drive this car. Right now I just want some tunes while I'm cruising this season
It's possible the car has the "active speakers" still in the car? Then an aftermarket headunit wouldnt work with the system, since both front speakers and the rear speakers are controlled by individual amps.
The front speakers were an easy replacement, the rear amp can be bypassed pretty easily as well
Edited by Hcr32typem
Expand
Yes it does have active speakers! How do I bypass those amps properly?
Expand
The front speakers should be pretty straight forward the rear takes some cutting and splicing. I'm trying to find the guide I used to bypass the rear amp that runs both rear speakers.
Found the guide I used.
I used crimable caps to seal the wires together, left the rest of the plug intact so that I wouldnt have any potential crossed wires. Works fantastically.
I'm running 4x6 in the front and 9" in the back. They're just cheap Dual speakers (cheap American brand) but they sound fantastic compared to the originals whose membrane had disintegrated like 10 years ago haha
  On 05/08/2019 at 1:42 AM, Hcr32typem said:
saudering iron
Expand
Now, it's one thing for you Yanks to say "soddering iron" (when it is spelt soldering, and said with the L pronounced like in the word "older", by the original architects of the language, and us Aussies), but it is another thing entirely to spell it the way you weirdos say it! Did you make up the spelling "sauder", or is that actually how some/all of you write it also? If so, where the hell did it come from?
  • Like 1
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
