57 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 40
ok here's the story...
for quite a while, the car has been doing this weird miss at idle. very inconsistent and gets worse when the car gets warm. really weird in that it would seemingly go away when the car is put into gear :confused:
so then took the car to the dyno day and was quite annoyed to hear that the car was pinging on the dyno. many ideas were running through my head which i posted in the poll...
so went down to see my mate Prassana at Performance Jap Specialist (9357 0658) as he has an r32 half cut there. he let me drive my car up and change over anything i thought might be causing the problem, and hte deal was to jsut pay for what the fix was. good deal i though. i changed:
- coils (got one and swapped it with all of mine to see if it fixed the problem)
STILL MISSING :(
- afm
STILL MISSING :rofl:
- O2 sensor
so feeling dejected, i went home and changed the spark pugs but it was STILL MISSING!
At this stage i suspected the fuel pump as it explained all my problems, but i also thought in the back of my mind that it could be a blocked cat. I was sure it wasn't the timing as when i had the GTR cams put in the timing would have to be re-done by my mechanic.
well on sunday, i washed my car and was armourall-ing the interior when dad comes into the garage and starts talking about the miss. we decide to check the timing.
already have the coil cover off (the plate that says nissan twin cam whatever) so plugged the timing light into cylinder 1 and started her up
THE TIMING WAS MASSIVELY OUT!
i think it was retarted (i had to turn the cas clockwise to bring it to 15deg btdc). would have been out about 10deg at least.
i was shocked.
so i adjusted it and took her for a drive down the street. WOW all the problems fixed. Wanted to give that timing light a ramming i was so happy :cheers:;)
if only it were fixed before the dyno day!
congratulations to the winners of "SAU VIC Armchair Tuners of the Year", 2004:
- fire_bringer_
- GTS-070
- Kor'axis
- MR R33 GTST
- Zahos
only 5 out of 42 got it right
well hopefully that brought some extra entertainment into the VIC section for a few days...
cheers,
Warren.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
