Interior Bits
All Parts in silver, in pretty decent condition. Only changed as I wanted to change the lot to black to match other interior bits.
Stereo Surround - $20
Dash Vents - $30
Climate Control unit (works perfectly): $200
OEM DIN Pocket slot: $50
Auto Shifter Surround: $25 (DOES fit with a manual conversion without fouling).
Triple Gauges (aftermarket Oil Temp, Water Temp, Boost). The text here lights up blue and pink/red as in the terrible photo from a video on this ad.
Comes with stock gauges as well if you prefer: $250 for all gauges/surround.
Oil/Water Heater and Thermostatic (80C)Sandwich plate for R34 Skyline, or any RB25DET - No Leaks, working perfectly. Works perfectly for an oil cooler, or the OEM part works perfectly if you have an old/corroded item! $50
Stock Intercooler pipes (engine side), intake, bov, and heater hoses (R34 GTT) $50 for everything in that photo
R34 Fuel pump and hangar. Working fine, removed from stock car. $50
Sony Single DIN Head Unit with Nissan Plug (R34 GTT). Useful if you want to replace the standard stock unit it you for some reason have one. Does not have BT - Has an awesome authentic AUX port and CD option. $25.
R34 Nissan Skyline AC Aircon Compressor. Working fine, only removed because of an Engine conversion and wouldn't bolt to the new engine. $100
R34 GTT Starter Motor. Starts. Has started for awhile. What else could you want a starter motor to do? $70
Nissan Skyline R34 GT/GTT R34 Indicator Stalk - Works fine, bought just for testing and turns out it wasn't the indicator stalk that was the problem. $30.
Bosch IACVBosch IACV / Idle air control valve. Worked great, incl plugs and resistor. Had this retrofitted to a Nissan Skyline RB25DETNEO motor to take over from the crap stock one that fails and costs $700 to buy.  No longer have said motor, so this is up for sale. Works great. Way better than the OEM item if you go anywhere near a track and get things hot.  $60
RB25DET Clutch Fan and Hub Near new (i.e not 20 years old, something like 2000ish km) fan and fan hub for RB25DET/RB25DET Neo. Still has Nissan stickers on it. Bought it a few months ago and then sold the motor it was attached to. Works perfectly, kept engine nice and cool under 20+ minute track abuse sessions. $250
Whiteline 24mm Front and Rear Sway BarWorks entirely OK. Trimmed one side of the softest setting to actually fit on a R34 though it's supposed to fit them from Whiteline. This thing is strong and stiff as hell and like me you will probably ignore the "Suitable only for race track warning. I hit a kerb once at the track and it broke the knuckle and the bar was entirely fine. Could use a lick of paint. Comes with spare bushes that I bought but never needed. Front and Rear included. Removed as didn't fit after an engine swap. $300 for both.
R34 GTT RB25DET NEO Engine Cover (Series 2) Comes with the coilpack cover $50
Happy to post if need be or pick up.
https://www.sau.com.au/forums/topic/477979-r34-gtt-parts-mostly-oem-junk/
  • 2 months later...
For any future searchers, all of the above is now sold except:
Interior Bits
Dash Vents - $30
  • 4 months later...
It's a bit late, but are these two still available?
@jrm They sure are! Shoot me a PM with details if keen.
Still have everything listed, all boxed up away from the elements etc ?
  • 2 years later...
  • 10 months later...
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
